Stock Ride height to the chassis rail at the rear wheels
gremlin
Pacific NorthWest
F150, looking to buy a ranger, some other toys
I looked on-line and through the forums but it could be my search foo has failed me. I'm trying to find out what the stock ride height is for a crew cab 4 wheel drive (Lariat if that matters) from the ground to the chassis rail at the rear wheel. With the service body on my rig I'm starting with air bags, but at the moment have no idea how much it sagged in because I stupidly forgot to measure this before the bed was pulled and replaced.
thank you.
I cant answer that but my suggestion is simple. Install the air bags, add enough air to give you a little extra height and add more as needed when adding extra load. Depending on the load will depend on how much air you need.
Canuckian
Canada
2022 Ranger Crew Cab Lariat Blackout
Literally just measured this and reported in another thread. 2022 stock Fx4 lariat crew is…
Rear Driver ground to frame right behind axle - 25 â…ť"
Rear Passenger ground to frame right behind axle - 26 â…›"
Measured right behind shock/u-bolt mount on axel to bottom of frame.
Was that with a full tank or no? Unfortunately the fuel in the tank will slightly affect this
gremlin
Pacific NorthWest
Thank you this will be helpful
A level on the bed of my box shows right now it’s level but I’m only mayb e 1.5” off the bump stops so I know its sagged in somewhat
