Side effects of no TPMS?
JeeperCreeper
Alaska
Jeep + Ranger Tremor
My Tremor is soon to arrive.
Looking for winter wheels and tires. I don't want to drop money on those dumb tire computers.
I run no TPMS in my Jeep, just has the little tire gauge light on in the dash, barely noticeable. That's the only side effect.
So if I run no TPMS in a new Ranger, what's the worst that can happen? I don't want my traction control to get jacked or the truck to go into limp mode or have anything buzzers go off?
Just a dash light? I hope...
Anyone know for sure??
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
I think… just the tire pressure light comes on.. I heard forscan can disable it but not sure. If you ever do want to get the TPMS, TPMS.com has the schrade ones for $30 a pop I believe. I used them in my winter set and good to go.
Lack of TPMS should have NO effect on any other system. Have had winter wheels/tires on several vehicles since 2005, all without TPMS and the only down side is the dash icon stays lit for the duration. Once you put the original wheels/tires with TPMS back on, the system will/should operate as normal and the system will recognize the sensors again.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
It's possible to move the the sensors to the winter wheels if you have the right valve stems. I bought a used set of OE charcoal wheels and just unscrewed the sensors from valve stems on my wheels and screwed them onto the new wheels.
That said, I bought all new sensors once for my old Sport Trac and when the batteries died again a few years later I just put a piece of black tape over the light. :like:
Dgc333
21 Ranger Lariat
FWIW, I got my 15 Mustang in January so I had my son order me a set of winter tires and wheels. The TPMS sensors were on back order at the time so I went without.
Every time I started the vehicle I would get a message in the productivity screen that there was a TPMS fault. Once I acknowledged it the little tire warning icon stayed on. It had no other impact on any of the other systems in the car.
Interestingly if I parked the car in the garage the system would pick up the summer tires that were stored in the garage and I wouldn't get the warning for 10 or so miles.
Joeiconic
2021 Ranger XLT
I like having the TPMS, since the tire pressures can be checked from the Ford app. I have found mine to be as accurate as my manual gauge and it’s an easy process to check all four tires at one time. I check my pressure several times a week while fiddling with the app and use my portable Makita inflator to top them off if they are low. I wouldn’t be that consistent with checking pressures if I had to do it manually. So, to me, the TPMS is a good safety and maintenance feature that justifies the cost.
