Show Us Your Garage/Workshop !
OFC Ranger
Jack
ZR2
Been busy shifting some things around.
A few weeks ago I dry poured a quick 1.5" concrete pad under the truck / between parking ramps. I will eventually go back and put down a smoothed 2" top layer. This pad receives no weight and its only purpose is so I don't have to lay in gravel anymore. I will eventually expand it so it all runs up to the concrete sill already in place. I also set me up a little chill spot in the back with my unused patio table and chairs. Nice place to sit and work on electrical stuff too. Sometimes sitting at a work bench for hours on end is a little rough.
Internal sliding and folding barn doors are cool from a novel stand point. However it gets a little old after a while. That and I was giving up valuable square footage in the front corners for clearance. Everything came down and I am currently setting is up standard like. Eventually a sort of boxed-in awning is going to close in the rail hardware to weatherize it and hide it. Paint to come as well of course. This method also required me to cut some "door passage" channels in the overhang of my roof. I did a quick hack job with some tin-snips, I will eventually go back and put some flashing back over it to make it pretty.
I plan to seal the top opening with some large weather stripping when I get to that point.
OFC Ranger
Jack
ZR2
Little more prep work before the weekend. Probably go in the morning when I get off work to get the small amount of lumber I need to make the awning joist.
My neighbor happens to have a bunch of old leftover black carport paneling so I'm going to end up painting that and using that as the awning roof.
Going to use the old silver paint I originally had as the primer see about getting a slightly darker tint so it matches a little bit better you can clearly see the color difference between what I painted today and the actual panel coloring of the garage.
The trim color is close enough though.
Still plenty of fit and finish work to do.
CF6-mech
JJ
OK, USA
2021 Ford Ranger 4x4
aircraft mechanic
I don't have much to show off now, but closing on a place wit a 40' x 60' shop. There is an apartment on one end. The open shop area is 40'x 40' with a 15' x 20' workshop area and apartment taking up the rest off the space. Looking forward to installing a lift.
NotBudule
XLT
Was just down at one of my (very messy) catch all buildings , this guy always saying "hi" .... Thats a WV trooper from way back , its modeled after the actual trooper ... They used to have a pipe mounted in roads that they put those in during school times , Can t remember the story or his name though...
Mellow
DFW, TX
Not so much about the garage I suppose, as much as what's in it.. lol
1 - Patriotic garage - red/white/blue
2 - International garage - U.S./Japan/Germany
3 - Trifecta - Truck/Sports Car/Motorcycle
Drop the mic....
OFC Ranger
Jack
ZR2
Well thats all I can get done till I am off again on Wednesday. I think the awning setup has come out really well so far.
Also, that little shit in the first picture ate my friggin Sushi I bought at the store I left out on the patio table while I ran inside to take a leak.
$9.95 gone in 60 seconds. You are suppose to enjoy Sushi not murder it.
Langwilliams
Langley
Lorain, Ohio
The shop is looking good OFC. I'm looking at a house with a 30x40 pole barn on the property with the tallest doors I've seen, a loft an a half bath. The barn is worth more than the house.
