FourMoreG
- First Name
- Geo
- Joined
- Apr 3, 2021
- Threads
- 0
- Messages
- 28
- Reaction score
- 57
- Location
- Hudson Valley NY
- Vehicle(s)
- 2021 Ranger 4x4 Lariat 501A
- Occupation
- Driver
I inspected my almost-pampered, 2021 Ranger with 5K miles, 4WD leather-SEATING Surfaces Lariat and there IS a Very small area of wear, in the “Rub Zone“, on the outer left side driver seat, NON-Leather, woven fabric section. BUT I have a habit of OUTWARDLY Left-leaning stretching the seat belt-harness BEFORE I attach it. This stretching action MIGHT have minimized wear to the affected area, but I’m not sure. I’ve been stretching the lap/seat belt for decades, since retractable seat belts were the standard, in order to reduce resistance AND getting a comfortable and effective fit. I try NOT to rush, ever, in the seatbelt fit. This Outward stretching May Have reduced the friction on my Ranger driver seat upholstery “wear Zone”. In any case, my appreciation to the OP and replies.After my Dealer told me this issue is not covered under warranty because it is normal wear and tear, contacted Ford and they said the same. They did record my report into a case and I sent a photo of the damage. If they get enough reports from owners it would be under consideration for warranty coverage.
I prefer a fix that will cover the wear spot as well as prevent any future damage. Did an intense amount of research about upholstery fixes and evidenty an iron on patch would be best. Mostly negative reviews from users of stick on patches and other methods of fabric and upholstery repair.
It appears that Amazon offers the best iron-on patch: Amazon.com: ZEFFFKA Premium Quality Fabric Iron-on Patches Inside & Outside Strongest Glue 100% Cotton Blue Gray Beige Brown Yellow Red Green Repair Decorating Kit 14 Pieces Size 3" by 4-1/4" (7.5 cm x 10.5 cm)
Here is one of the reviews that is attached to it: By R. P. on February 8, 2021 Used the patch on a seat in a 2008 Jeep. Went on easy and a month later still there.
I would probably in addition to covering the worn spot with it, also apply some of it on the inside of the belt where it sets against the seat back for extra protection.
If this doesn't work then I would use a seat belt pad like some of you are doing.
Any thoughts?
Indeed.
This truck is used almost daily, which roughly figures 2 rubs per driving event; one attaching & one returning.
I will also consider coming up with alternative(s), to somehow, placing “roller” style jewelry beads, (or similar Or other possibilities, to offer choices to a Faux sheepskin solution, to act as a friction-reducing spacer and significantly reduce damage). I must now consider one or more methods (available genuine Leather patch material, durable plastics, ceramics, metals ? Whatever), to how best make a simple, wear-reduction, effective design, that Does Not hinder seatbelt function in Any way, And, provide a choice to the faux sheepskin option. Faux sheepskin may be subject to early wear And May only be a temporary solution, one that I will probably promptly use, until one or more successful, permanent alternatives are designed.
It would NOT hurt if FORD Corporate acted on this issue, with Zest. This May be a design flaw, regardless. It is an avoidable condition, but if the wear continues, will only be permanently corrected by an expensive fix, one that could be made non-existent, with some intelligent, cost-effective design, thought thoroughly UP FRONT.
Maybe ?
To Ford:
are you paying attention ?
We shall see.
