RSI SmartCap - New Product!
Status
Not open for further replies.
OffroadAlliance
OffroadAlliance
Brockton, MA & Houston, TX
www.offroadalliance.com
2019 Ranger, 2021 Raptor, 2022 F250, 2023 Bronco
TomC
Florida and North Carolina
2020 ranger lariat supercab FX4
Family vehicle MX officer
Info is rather limited, but if you have specific questions we're happy to investigate and get back to you.
This thread is the first time I have seen this.... interested.
Can the bed replacement system be done by the truck owner or will the vehicle have to be taken to ??? to be installed? Is the factory receiver kept and used? backup sensors/camera kept? weight breakdown? I actually searched copart for another ranger that got rear ended...sorry for all the questions.
Hi Tom,
Spent two months in New Zealand and Australia. In NZ Ranger is the #1 vehicle. In Australia it is Toyota, but most have no pickup box and have such a flat bed. Seems to be cultural... I am guessing the Aussie's order with a box delete and put these flat beds on the back. Also, snorkels abound for the Dust...
best,
TomC
there is a guy in Bradenton who does custom beds...
the RSI bed replacement system looks like a great option. Here is what I was looking at....I just have a hard time taking off a good bed, hence the search for copart rangers that got rear ended.
Hi Ray - I’ll update once I get this thing out of the garage! I’m assuming I’ll need to plug the gap at the front to keep out weather. Chris mentioned above he’d sort out the brake light cable. My only other feedback so far is that I was expecting this to clamp onto the top of the bed rather than having the mounting brackets, based on this pic on the website.
I have an ARB drawer in the back and the side floor will now need some cutouts around the brackets. Something to consider if you have or are planning to have drawers in the back.
I way considering a drawer system fr ARB with this cap. Do you have pictures of the draw system with the cap fitted and where you had to cut? Also did you get the extra floor kit for your drawer kit? I know it is a little off topic but it may help others here.
Hi Tom,
best,
Too my understanding most full size trucks in Australia and possibly NZ come with flat beds from the factory. Mid size trucks might have the option but it is still up to the owner if they want to change the bed for a different style.
RangerTaz
Alex
San Diego
Agree on the rack - I’m gettting a low profile Front Runner rack installed in the next couple of weeks. I’ll update when I have images.
Here it is with the FR rack on. I like the combo. Definitely needs the extra leaf in the back, as sitting about an inch lower than the front with the weight of the RSI cap and ARB drawer. I’m waiting on some Icon rear shocks before doing this (back ordered forever...), if anyone wants to sell me some!
RangerTaz
Alex
San Diego
Here is the ARB drawer (RDRF1355 + half of the MA19FKEK side floor kit) with the RSI cap installed
I had to notch out 2 of 3 side floor panels to make room for the RSI mounting brackets. I separated the carpet from the plywood, cut out the notch with a saw, then glued the carpet back in place and trimmed off any excess.
When I park at home, I back up pretty close to a wall, so don't have room to pull the drawer all the way out. A nice feature of the roller floor version of the drawer is I can access the back of the drawer (towards the front of the truck) through the side window without having to pull it all the way out. Just need enough space to open up the tail gate. I'm also quite tall (6'5") - this may not work for everyone!
In other news, the harness RSI sent for the 3rd brake light doesn't work with the LED taillights. I ended up getting it spliced into the taillights.
AutobotXJ
Ray
Volcano, HI
2020 Ford Ranger
Wildlife Biologist
that’s terrible for such an expensive product. Everything should have been designed for the truck. Did the RSI company advise you that you’ll need to splice?
r1ch999999
Rich
Nashua, NH
Software Engineer
If that flatbed worked with the LED lights and sensors, and was maybe a touch longer than stock, I’d be a lot more interested.
RangerTaz
Alex
San Diego
RSI will take care of the splicing cost. I think they are working on a new harness that will work with the LED lights, so it will be more plug and play.
RangerTaz
Alex
San Diego
Added a couple of LED strips inside the Smart Cap. Can select red (for night use) or white with a toggle switch and have a dimmer to control brightness. This is wired to the battery. Switch/dimmer are mounted on the vertical face of the ARB trim panel to the right of the drawer.
Status
