Roush Iridium Gray 17x8.5 +25 offset
Bdem62
Kevin
Iowa
Director, Safety Division
watersniper
watersniper
Virgina
Marmota Monax dental plan administrator
Thanks! I thought you bought a set last month. You haven't gotten them installed yet?
Sadly no not mounted. Life is getting in the way ?
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Tire & Wheel Specialists
PRESTO! I got them installed today with set of Toyo Open Country AT3's in 275/70-17". Fit like a glove and the Iridium Grey really compliments the Rapid Red.
If anyone is on the fence about these wheels, they seem to be really top notch. I for one are very impressed with the quality and finish.
Sweet looking set up ! Than you for sharing!
watersniper
watersniper
Virgina
Does this Scarlet and Gray masterpiece have a level/lift? Anti intrusion crash bars, any rubbing, etc?
watersniper
watersniper
Virgina
FINALLY got ‘er done! Roush wheels, Nitto Recon Grappler 285/70/R17 116T’s, ReadyLift Intrusion beams, Eibach Pro Truck 1.0 level kit. I’m an idiot and did that Eibach kit myself. Took ALLLLLLLL day yesterday. Couldn’t get the Eibach springs compressed enough to fit so I resorted to re using factory springs and 2.25” setting. I wanted the 3” front lift…. I was not a fan of reusing the spring mounts- definitely worth it to buy a proper adjustable 2.0 kit. FYI. Still though, no rubbing! I have a set of Eibach 1” rear blocks just in case.
Finding a local tire shop willing to mount the tires was a chore! All in all - super happy with this setup.
watersniper
watersniper
Virgina
Oh and the Eibach kit was mis-packed with the wrong rear shocks- so I will have to fight with them/Stage 3 on Tuesday. ?
RangerRandy
Randy
Hiram
2020 Ford Ranger
Paint and Body
Lookin Good!
fx13tl
TN
2020 Ford Ranger XLT FX2 302A
Curious how these would look on an Iconic Silver.
watersniper
watersniper
Virgina
I think I have sufficiently screwed the pooch here guys. Need your advice. Since I added this wheel/tire combo I have noticeable vibration from 65-75 mph. From about 60mph and lower it’s smooth driving.
285/70r17 Nitto Recon Grappler on the Roush wheels. I had Them mounted by a local shop that didn’t seem the most technologically advanced. Took the truck to a high end aftermarket wheel shop and they performed the detailed balance service (roadmaster?) no luck - same vibration at higher speeds. I bought the tires from www.simpletire.com and it seems I will have to do quite a bit of legwork to try and prove the tires are out of round.
I did the Eibach front stage 1 level so that’s the only other question - did I screw up something with that?
Colo_Ranger
How long did you have the lift before the wheels and tires? Did the vibration start only after the wheel/tire install? A high speed vibration is generally tire balance. Roadforce balance will help determine if the tires are out of round. Any tire shop should be able to warranty the tires through Nitto. Do you have a Discount Tire near you? They are great.
