- First Name
- Dave
- Joined
- Jul 25, 2019
- Threads
- 342
- Messages
- 27,112
- Reaction score
- 137,222
- Location
- Back Home In AZ!
- Vehicle(s)
- 2023 Ford Ranger Tremor
- Occupation
- Retired...Full Time Slacker
- Thread starter
- #1
I received my Wolfbox 4 in 1 Jump Starter with Air Compressor a few days ago and finally had time to try it out. At first glance it comes very well boxed with a nice case that stores everything neatly inside. I really like when a company includes a hardcopy manual along with a quick guide manual instead of having to look everything up online. The unit is extremely nice and heavy duty weighing in at just under 4lbs. It’s solid and doesn’t feel cheap like most other jump starters do
One noticeable feature is that all the controls are right on the front making it very convenient and easy to access.You’re not fumbling around looking for them on the sides of the unit like most other jump starters are. The only thing that would’ve made this better would’ve been having the buttons backlit. The LED display is huge and very easy to see and read in the dark which is where you’ll most likely end up needed it at one time or another.
Another really nice feature is the auto air stop. You set your desired psi which is adjustable from PSI, BAR, KPA or kg/cm by pressing the psi button and it’ll stop at that setting and has a max setting of 160 psi. No watching gauges or having to look at the TPMS sensors then adding more air or taking it out because it was overfilled. I let 10 psi of air out of a couple of my tires just to test this out and it filled them fast and they were all at the set psi which I double checked with the TPMS sensors and my tire gauge. You can also toggle through different modes from car, motorcycle, bicycle, ball and custom modes.
It took about 2.5 minutes to fill it up to 40 lbs. Usually it's 39 lbs but my tires were still warm from being out earlier so I added an extra one.
I didn’t get a chance to try out the jump starter because I don’t have a dead battery. lol The cables are very heavy duty and are just over a foot long so they’ll be easy to use if/when you need to jump a vehicle. The clamps are also heavy duty and have very good spring retention on them, they’re not falling off!
The last features are the LED light & USB A and USB C. You can charge your phone or tablets from here and once a device is removed the unit will auto shut off in 90 seconds. The LED light is bright and will come in handy if needed at night and especially seeing as our Rangers don’t have a light under the hood.
There are 3 modes which are constant light, flashing and SOS.
Overall this is a very high quality jump starter unit and I’d highly recommend getting one if you’re in the market for one. Plus Christmas is only 5 months away so this would make a great gift.
Thanks again Wolfbox @Wolfbox for being a great sponsor here on R5G and having these giveaways for us members here.
