Removing the whole 3rd Brake Light Unit?
Mirage775
Huntsville, Alabama
Water Meter Tech I
I'm replacing the whole 3rd Brake Unit with a Smoked LED one. I need to know if anyone has removed or knows how to remove the whole 3rd Brake Light unit? I read something about the connector being under (above) the headliner? Is there a way to reach it without having to remove the headliner at all?
I would appreciate any help whatsoever?
Thanks!
Danager
Dan
Alberta
2019 Edge
Manager
Remove the screws from the outside. Once the light assy is out, the the wire runs inside and is behind a piece of tape that blocks off the opening. Push the tape in and you can reach the plug. My wire was also attached to the sheet metal with a retainer clip. Pry that out and there is plenty of slack.
Mirage775
Mirage775
Huntsville, Alabama
Water Meter Tech I
Awesome! Thank you! I couldn't find anything from a Google search... It was all about changing blown bulbs.... I should have the new light this weekend?
WOADKIL
Wil
Cyber Orange County, CA
2021 Ranger XLT Supercrew Cab FX4
RETIRED ENGINEER
Thanks!
Where did you get the brake light?
Mirage775
Mirage775
Huntsville, Alabama
Water Meter Tech I
WOADKIL
Wil
RETIRED ENGINEER
