Fitzmotor
Gold Sponsor
You just did, thank you very much for your interest?Would love to get on this purchase list.
Thank you very much, it can be crazy at times, but it's a good thing.Mike this is a beautiful thing, the orders keep coming in, even new members as they hear about your Fitzstick. All us members are happy for you and your awesome dipstick is terrific.
When cold, the new stick should read about 1/16th of an inch higher fluid level than stock, when hot it is the same.I checked the level, so in the ball park of correct fluid from the factory.
Guessing just moving/flexing the line gives enough clearance. I had a hell of a time loosening that bolt because of the hood shock/strut and it didn't seem to buy me too much. I would just try flexing the line for clearance right off the bat.Ok....I read the instructions and watched the updated video. It seems something is missing from the video.
Around 8:30 into the video, he talks about nudging the A/C line to give more space.
The instructions say to loosen a bolt 1st then push the A/C line up and back...then tighten the bolt.
I didn't see him loosen the bolt in the video. Just nudging the A/C line. Should there be something about loosening the bolt 1st before nudging the A/C line in the video?
Well looks like you should loosen the bolt, its down below the ac line in front of it to the left if your facing the truck. If you don't have the hood shock it will be easier to get too.I don't have mine yet. Should get it next week. I tried to move the A/C line and it doesn't move at all. Just want to make sure I'm doing this right when I get the product.
First get it installed, most have no clearance problem, then if it’s a little close, you can do either or both, the bolt will move it some, depends on where the guy on the assembly line tightened it at.
The A/C line is actually easy to adjust back as well, it just doesn’t seem like it.
It should be no problem at all?
