Remote Switch for Lights
JesseS
Jesse
NorCal (Roseville)
So as a retired LEO I have mounted many emergency lights in my POV, all were a PIA to wire the controller in the cab. There are solutions out there but most are very expensive. I have dealt with Strobes-N-More for years for lighting solutions so took a look at what they are offering. They have a Touch 6 unit that is very nice, includes everything you need for six outputs, but still requires a single multi-strand cable thru the firewall. The Feniex 4200 is very nice also, programmable, multi touch 7 button, but again you have to run a wire thru the firewall. Then I saw the EZ Remote wireless switch box, a 4 button remote like a garage door opener, and a control box in the engine bay with 2X 10A and 2X 20 amp outputs for lights, and it is on sale for $40 right now, so I ordered one as the reviews were good. This site sells equipment to First responders and emergency response departments. They also sell to the general public but some items will require a ID. (mostly restricted things like Blue lights and Sirens)
Here is the link for the 4 channel remote switch if interested. EZ Remote
And for the touch 6. Touch 6 Controller
RecoilOperated
Albany, New York
2020 F-150 XLT, 2022 Subaru Outback
ICU Nurse
The product page for it says that it needs to be mounted in a clean and dry location; if you're mounting it under the hood where are you planning to put it?
JesseS
JesseS
Jesse
NorCal (Roseville)
I have a small waterproof plastic box I will use, with rain tight pass through connector for the cables, not a problem. The case is sealed, it is just the screw terminals for the light wires that are exposed, you could also use a liberal amount of dialectic grease on them. The top of the fuse box might be a good place, never going to get that deep in water.
JesseS
JesseS
Jesse
NorCal (Roseville)
I looked at them, but at 10X as much its a non starter. $400 vs $40.....Hmmmm... let me think.
I wouldn't trust that $40 unit. You get what you pay for.
JesseS
JesseS
Jesse
NorCal (Roseville)
I thought about that, but I have purchased a LOT of emergency lights and equipment from this company over the years, they mostly sell to 1st responders, and everything has been of good quality and lasted well. Just because this switch isn't marketed directly to the 'Off Road community', and doesn't have the bells and whistles doesn't mean it won't do the job. I am more about functionality than looks in any case, as long as it does what it says I am good, and for $40 (not even the cost of lunch) I will give it a go.
That would be the one instance I'd go against my norm and get the cheaper version.
Generally though when looking at a 90% price difference you're going to give something up. Looking at the one you linked to it seems pretty flimsy to me. Obviously there will be some functionality differences as well.
Hope it works out for you. If not at least it's cheap.
JesseS
JesseS
Jesse
NorCal (Roseville)
Exactly my thought, besides, there is absolutely no reason that a remote switch should cost $400, in most cases you are paying for either looks, the name brand, or things you don't need. If it lasts a couple of years it has more than paid for itself.
You get more than 10x the cost though...
1-it eliminates the need to go through firewall
2-it consolidates all power distribution through one solid state, multifused unit
3-it eliminates individual relays for each power supply
4-it's both WIFI and bluetooth controlled
I shopped around and got a new Trigger 6 for under $300...
JesseS
JesseS
Jesse
NorCal (Roseville)
That's a good price for the Trigger 6, not sure why I would ever need wi-fi as I don't drag a router around with me, BT is a possibility (have it on my RV batteries) but at 30' range (for most) it is shorter than the included remote. This unit isn't waterproof so I mounted it inside a small waterproof electronics box with a single water tight pass through. I have tested it with a load and it seems to work well, and the remote's range is in excess of 50'. As all of the wire leads are in and go to one spot it would be simple to replace it with something else if the need arises.
