Rear axle weight limit?
GreyThumper
Dino
Philippines
Ford Ranger Raptor, a BMW R1200GS, a BMW R1150R
Anyone know? A fellow Raptor owner had to do an emergency transport of his friend's bike. It's around 250kg, well within the Raptor's payload, although we were concerned about the load on the rear axle.
JesseS
Jesse
NorCal (Roseville)
500 lbs on the rear isn't going to bother the axle, but depending on how that bike carrier is mounted there might be an issue as that exceeds the tongue weight. I would assume a double or triple hitch setup, frame mounted, which would be fine.
GreyThumper
GreyThumper
Dino
Philippines
isnt it listed on the door sticker as the GAWR?
This is the frustrating bit. I'm in the Philippines, it isn't listed in our local Raptors. The door sticker only has recco'ed tire pressures.
Your owners manual should mention both the payload capacity and the towing capacity(toung weight included). Chances are I suspect you will be ok taking it slow but be aware that if not careful things can go south real quick.
KNI
Finland
Ranger Raptor 2021
On stock raptor the sticker limit for rear axle is 1580kg (inc payload+vehicle). Payload max is about 500kg. Towing capacity 2500kg.
GreyThumper
GreyThumper
Dino
Philippines
Yup, payload and towing capacity are pretty easy to find, I was concerned about maximum axle load, specifically on the rear axle.
Most likely more than payload to say the least
myothercarizahearse
Cleveland, Ohio
Unretired
Here. So dumb. At the very least, they should put max payload. I'll bet a lot of people overload their Raptors here.
laws and regulations probably aren't as over bearing in the Philippines
WOADKIL
Wil
Cyber Orange County, CA
RETIRED ENGINEER
So the rear axle is what supports the stated load capacity, along with the frame, front wheel axles, bed, springs, etc...
The 1,560 to 1,860 load capacity includes all these elements. Tongue weight capacity is what the hitch structure can handle.
bill_AUS
Billy
Victoria, Australia
2020.75 Ranger Raptor, 2013 Ranger XLT spacecab
Vehicle fleet engineer
The pertinent numbers for the Ranger Raptor (in Australia at least):
