Real Reason Why Ford Bronco's V6 Engines Are Failing
After a bit of digging up and help from forum members, it’s evident that the Bronco’s 2.7L V6 engine is prone to valve failure. A member—whose account has been sadly deleted—claims the issue is due to the valves used in the 2.7-liter V-6, supplied by an outside vendor to Ford's Lima plant.
Real Reason Why Ford Bronco's V6 Engines Are Failing (msn.com)
NotBudule
XLT
I read the stems were brittle and breaking off dropping the valve , some with less than 10 miles ! Not sure if it's really true though ?...
They were supposed to have fixed this well over a year ago. There's a huge thread on it here on B6G with 65 dead 2.7's to date. Then there's the fuel pump issue where going up a steep incline and down a steep decline is killing the pumps. Some have said they had 3/4 tank full so it's not an issue with low fuel.
Not sure why other manufactures aren't having these same issues but it seems like Ford can't find good suppliers and/or is cheeping out on the ones they're using. As much as I want my Bronco I'm almost glad I don't have it yet.
SigOris
Greenwood Maine
Retired DoD EE
Not only that, where would you install a damper ??
Jbrubakerjr
Woodstock, GA
2022 Ranger Lariat
