Question for how you installed lights in front bumper area?
Zims4x4
2022 Ford Ranger XLT Forged Green
Question for anyone whos installed a light bar or lights in the front bumper area. i found the removable 4 holes but how was anyone able to access the holes? did you remove the skid plate from below? or remove tire like how to change your oil ? or did you somehow remove the grill? Once i put the light bar in , i cant get my fingers in to put hex nuts to secure it place? Any help or ideals would be greatly appreciated.
chrisakz
North Jersey
2019 Magnetic Supercab XLT FX4
I have ACC radar in the way so I put 2 6 inch lights there instead but I used the push pin holes that are along the top side to mount them and you can access the back side to put nuts on. I also removed my front plate bracket a long time ago and there were extra holes there. I never looked at the bottom side
RD_Kona
Steven
Denver
2023 Ranger XLT Tremor
I used the spots for the push pins just outside the license plate bracket holes. It wasn't easy to contort my arm up there to put the nut on the mounting bracket bolt but it wasn't impossible.
Zims4x4
Zims4x4
i didn't think of ACC sensor , i don't know if i even have it on mine, i know I've never tried using it. But with the light bar i cant get to the back side, i might go down the path of smaller lights.
chrisakz
North Jersey
You can’t miss it if you have it. It’s a big box in the center of the lower grill opening there.
hookem57
Don
Fort Worth
2021 Ranger Tremor
Driver
I put a Bull Bar on mine so can't help you there.
Pull out the plugs, insert pod bolts and tighten nut above...
OregonRangerTremor
Craig
2021 Ranger Tremor/2022 Bronco/2006 ChargerDaytona
Retired LEO/Dog Trainer
Diode Dynamics. It came with the bracket. No need to remove anything to install. Look at their web page and instructions...may offer some guidance. These do not interfere with center
sensor.
ylwjacket
N. GA
2019 XLT FX4
I had this in there, but had to take it out to put winch in.
I took off the skid plate, them just found a bolt on each side to connect it to. I got a piece of punched flat bar from home depot, painted it black, and bent it to connect the ends of the light to the bolts.
I did the same thing for the white bar behind the grill.
Zims4x4
Zims4x4
I put these in the actual bumper. Best idea ever had to remove the bumper and the plastic inserts needed to be modified but what a great addition
was removing the bumper a pain?
