Possible leveling kit change.
Ranger Off Roading
Ray
Florida
2023 Ford Ranger Lariat Tremor
I installed a readylift 2 inch leveling kit on my 23 Tremor but used top spacers only from the kit since readylift says not to use the bottom spacers. I called readylift and asked what the thickness was of the top spacers and they said they were 1 1/4 inch. Want it to be leveled but it is not. Seems to be about 3/4 of difference between front and rear. Would it be safe to switch to a 1.5 or 2 inch leveling kit to make level?
baloo2650
Eric
Elmira, Ontario
2021 XLT Tremor
Millwright
I think the rule of thumb is that you get double the thickness of the spacer in lift out at the wheel.
Joe_seph
Canada
2021 Ranger Lariat Tremor
Electrical Engineer
I installed the bottom spacer on my ā€˜21 Tremor. All you need to do is make enough space so the Fox shock doesn’t rub on the spacer. I filled some material off this area to make it work.
(Note, it’s aluminum so don’t use a grinder for safety reasons)
Ranger Off Roading
Ranger Off Roading
Ray
Florida
Interesting, thanks for the info.
