Portable compressor for airing up them tires
_TraMor
TraMor
Upstate NY
22 Ranger Tremor, 17 Focus St, 97 Escort Wagon
IT by day, shade tree Mechanic... also by day
I'm not sure if there's a better spot to put this but I'm looking for a reasonably priced inflator to take my 33" from 15-35 psi.
I "think" I have it narrowed down to;
OR
I'm kind of leaning towards the 88P since I would be doing one tire at a time. I just know the cigarette lighter one I have now is running on borrowed time and I should get something else on deck before it let's out the magical white smoke.
What's everyones thoughts, suggestions, other options?
Joeiconic
The Viair is tried and true. I carry the 88 in both of my vehicles. I have a battery powered one in my garage to just top off when needed. I wouldn’t rely on it on the road though.
Can't speak for those two but I can say the ARB Single compressor has done me well. I got it when I had the Ranger and it took about 8-10 minutes to air up all 4 tires from 18 to 30 PSI. That was with 33's. Still have the compressor for the Pathfinder and it takes a little less time since it has 31's. To be specific I got the Ford Performance one from Stage 3. It is the same as the ARB but with a blue hose and the Ford Performance sticker. Sometimes it will go on sale.
OR
I like Viair...this is the one I use...
https://www.amazon.com/gp/product/B000X9B32M/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Potterz
Pismo
2020 Lariat
I recently got and tested a GSPSCN inflator (double cyl) from Amazon and it works very well. I was concerned it's rated at 25 amps, but I used the 12V dash socket (20A fuse) with no problem. Very fast, very compact, good price.
Steve 2020 Lariat
RangerPNW
Thomas
Santa Fe, NM
I carry the Viair in my truck, and I'm quite happy with it for as little as I use it. If I was airing up more regularly however, I would probably get something more substantial.
Please elaborate a little more for the last part. Do you just not go OffRoad much so you don't air up much or is the compressor more of a backup?
Radioman
Kent
Roseville, CA
OR
VIAIR makes great products and I recommend them. Personally, I have a 300P which I use for my Jeep and also to blow up air mattresses when camping.
Ranger_Rocks
Wandering
Wanderer
Good info on portable units mixed in this thread...
On board Air setup on your Ranger
I considered Viair and others. Then I thought about stowing the individual pieces, sitting in the dirt/mud while airing up, sucking dirt/dust while sitting on the ground, etc.
I ordered the Ford Performance ARB compressor from our forum sponsor Benny @LevittownFordParts.com
https://www.levittownfordparts.com/sku/m-1830-fpac.html
Our entire air up/down solution stows nicely in a single box.
Compressor, hose, cables, spare fuse, tire gauge, ARB Digital Tire Inflator Gauge, Staun Automatic Tire Deflators, and tire plug kit.
Having the compressor mounted in the box keeps it clean and helps prevent it from tipping over.
We find this kit quick and convenient for our air up/down needs.
Pics from when we first received it...
I'm curious on how you like the digital tire gauge? I have considered it, but I'm. It too sure
Ranger_Rocks
Wandering
Wanderer
Love it. Our ARB Digital Tire Inflator Gauge makes pressure checks, airing up, or down (few pounds) a snap. Attach it to a valve stem, stand up, then squeeze handle to adjust pressure, or release handle to check pressure. Stays connected to the stem until you're done. Solid quality build, easy to read lighted display, hose length permits standing up while airing.
For airing down more than a few pounds, we us our Staun Automatic Tire Deflators.
Our tires are always hot when airing up, so I set the pressure 3-4 PSI above our normal 37 PSI. Next day after the tires have cooled, I use the ARB to set the pressure back down to 37. Easier than hooking up the compressor to add 1-2 PSI to each tire.
I use our compressor kit on both our Ranger and Santa Fe. Also came in handy one night to set the pressure on our new water heater expansion tank. So far not a glitch and still on original batteries.
For pressure comparison or backup, I also keep one of these in our box. Readings closely match the ARB and TPMS. After using our ARB and gaining confidence, I seldom use this.
