Pet Peeves
WVmanowar
Greg
Lorton, VA
not a truck
Auto-start stop
That damn double-honk when i get out of my running truck with my key in my pocket. Either give me a proper key and switch or stop annoying me when I use the convenience feature.
That double horn blow when I get out of the running gtruck is too loud of a warning. It makes me jump and I'm sure the neighbors love to hear it too. I keep the keys in my pocket and forget; makes me jump each time.
Ranger Danger
East Coast USA
2023 Ranger FX-4 Off-Road BLK PKG Cactus Gray
Stay at home puppy daddy
It moves more air and it's needed for the turbo intercooler, and the fan runs hard at cold start, then goes away.
Like he said, and I read here it is more reliable than an electric fan, and has a higher output.
BHunted
Sumner County, TN
Dumb lil center speaker emblem on dash reflects on windshield. Looks like a UFO bopping around. Going to black it out.
Hi James,
I have read that the fan is controlled electronically. I have searched for these wires and please to those that said this show me where they are located. I highly doubt this is the case. This fan noise is called morning sickness. The silicone fluid drains to the bottom of the fan clutch, which locks up the fan clutch until the cold start engine rpm throw the fluid out of the lock up and the fan quiets down. So where is this electronic lockup? It should be able to be disabled in Forscan if part of the ECM..
I remain unconviced this is a calibrated item in the ECM.
DavidR
Eastern CA
2019 Ranger XLT Supercab Saber FX4
Hi James,
Ours has a wiring harness that at least appears to terminate at the fan clutch (see photo below), but correct me if I'm misinterpreting that. Since I first noticed that, I've been wondering if there is an electronically controlled clutch in parallel with or in series with the fluid clutch. Even so, I agree with the morning sickness effect - both our old Ranger and Aerostar did that.
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
Damn some of you sure are picky, like a few others I don’t understand the want of a tailgate damper, it weighs like 5 pounds.
My only complaint is that when air is blowing out the top vents it is great but when turned 50/50 lower and upper vents. It barely blows anything out and sounds like most of the air is behind the dash blowing. Dealer said there’s nothing wrong with it
Deleted member 1634
How are you getting so many miles on a tank? I only get about 380
No idea, I drive it the same way I drove my Tundra V8, and Tacoma V6 and not shy with the gas pedal. The range was at 420 when I picked it up from the dealer which saw no highway miles. Since I've had it, it's rose from 420-470, last fill up it registered at 450, and I've been filling it with 93 octane from day one. We have 87, 89, and 93 Octane available here. Since my past Turbo's always needed 91 or better, and the manual says it will run on 87 yet higher is better I kept filling it with 93. The new Tacoma V6 engines (not a turbo) can run on 87, yet 91 is also recommended. I wonder for longevity, and performance what level of octane is best in this 2.3L Turbo?
That's just by getting 26-28 mpg. Very doable if you drive eco-concious (not even hyper-mileing). Even when running 87 like I do. I've gotten over 500 miles on a tank before. Granted that was during all highway driving, but it is still very possible.
Ronbo
Ron
FL, CT, TX
2019 Ford Ranger XLT FX4+
Damn you’re picky :yawn:. I don’t understand what the problem is, you’ve got 4 windows you can open up for air.:whew:
JK, only funnin with you.
BHunted
Sumner County, TN
I had put dampers on all my trucks.... Especially full size. Don't have to worry about them slamming down. Get whacked on the leg or knee once without one and you'll want a damper. Also easier if one hand is loaded with goods. Easier if you are getting older, it helps too. Got arthritis in my hands. So, not about being a weak pussy, it's about common sense and why the hell doesn't manufacturers just throw them on? Why put them under your hood? Use a 2x4... isn't that cheaper and easier? </sarcasm_off>:sunglasses:
MasiJC
Joseph
Northern NJ
2019 Ranger SuperCrew Lariat Sport - Magnetic
IMO the call accept / hang-up steering wheel controls should be reversed.
Can't tell you how many people I have hung up on accidentally.
DavidR
Eastern CA
"If the sensors used by adaptive cruise become blocked by snow, the truck completely disables cruise control instead of automatically falling back to normal (non-adaptive) cruise control."
isnt that a good thing though? you dont want to use cruise at all when the roads are slippery
That depends a lot on the conditions. If snow is sticking to the road that's true for sure. This particular time, a few weeks ago, it was above freezing, snowing lightly, and not sticking even slightly to the road. The road was wet, not snowy. Also, snow isn't the only thing that could block the sensor, it could be bug hits or someone splashing mud onto your car before getting on the highway, or just having followed someone down a dirt road, etc. It could even just be normal dirt that accumulated to the point where the computer decided the sensor was not reliable enough. I don't think you can say that all things that will cause a blocked sensor will result in a situation where normal cruise control is unsafe, though certainly some do.
HenryMac
Mech. Engineer - Retired
Then make them an optional item that is dealer installed. Many of us are tired of paying for things we don't want.
I'm ok with prop rods on the hood, manual windows, manual door locks, etc. Less is more.
THLONE
Thom
Tucson,AZ
internet wise guy
Ford is not going to add all of these trinkets and do dads for free. So when you ask for something then also say how much you want to pay . :shock:
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
Same, the less things to break the better! I got a base XL but still got more than I wanted
