P139C Code
emesel
New England
I'm getting a P139C code with rough engine at low speeds. When I looked it up it says cracked hose or failed valve. Should I just assume it's the valve and replace it? Is it important to get OEM, or is something from Autozone ok (I usually buy OEM for things like brakes, etc)? Is it ok to drive in the meantime?
Thanks, Mark
RangerBill
Thanks, Mark
From the shop manual:
P139C - EGR Sensor C Downstream Hose Off Or Plugged
Description:
At idle, the exhaust gas recirculation (EGR) monitor commands the EGR valve closed and checks the differential pressure across the EGR tube orifice which should be zero to indicate the hoses are connected and not restricted. This DTC sets when the differential pressure indicated by the sensor exceeds a maximum threshold or falls below a minimum threshold. Possible Causes:
  • The downstream hose is disconnected
  • The downstream hose is restricted
  • Restricted or damaged EGR tube
Diagnostic Aids: Look for signs of water or icing in the hose. Verify the hose connection and routing. Check the differential pressure feedback EGR sensor for correct mounting and function.
Check for the proper connection of the hoses to the EGR DPFE sensor. It could be a bad EGR DFPE sensor. It is about $20 at RockAuto.
The Standard Motor Products is the OEM manufacturer.
https://www.rockauto.com/en/catalog...sion,egr+pressure+feedback+(dpfe)+sensor,5088
Here is a thread on the replacement procedure:
https://www.ranger5g.com/forum/thre...mbly-replacement-write-up-lb5z-9j433-b.29247/
emesel
New England
Thanks RangerBill!
I just bought from Rock Auto; I don't know why I frequently forget about them.
An FYI, I checked a discounted online OEM Ford source: it was $132 discounted from around $200, which included bracket, hoses and clamps, but, still really expensive.
Thanks again, Mark
From my (Detailed System Ops)
P139C - EGR Sensor C (DPFE) downstream hose off or plugged (Low > High)
During idle operation with EGR commanded closed, the PCM expects the pressure at the upstream (HI) and downstream (LO) reference ports of the DPFE sensor to equalize, resulting in a differential pressure near the learned KOEO baseline. The PCM continuously evaluates the DPFE signal for rationality and monitors for excessive negative differential pressure. If the DPFE signal remains below the calibrated lower limit of (−0.58 psi) for approximately 50 seconds, indicating a sustained pressure imbalance or sensor signal outside the physically plausible operating range, the PCM identifies the signal as invalid and sets DTC P139C.
P139C sets when the PCM detects the DPFE sensor signal remains below (−0.58 psi) for approximately 50 seconds during idle conditions with EGR commanded closed, indicating an implausibly low differential pressure and a fault in the DPFE sensor or pressure reference system.
Ref the (-0.58 psi) note this is well after the buck surge zone of (-0.35 to -0.45 psi) so this highlights why the buck surge issues are experienced before the P139C code sets.
P139C sets when
Using Learned Zero – Voltage & Pressure as Ref Values
So if using Learned Zero Ref of 1.48 volts = a voltage reading of about 0.96 to 1.07 volts will trigger the code
Trigger Time Duration = 50 Seconds
Trigger Pressure / Voltage – (-0.58 psi) / 0.41 to 0.52 volts
The monitor is a continuous monitor and monitors at Idle only, no EGR flow.
The monitor is a (Negative Imbalance - Monitor) - Low Pressure > High Pressure
P139C –Possible Causes
  • DPFE Sensor – internal bias failure (moisture)
  • DPFE Sensor – internal diaphragm damage
  • DPFE Sensor – electrical fault
  • High Pressure Hose / Port – restriction – blockage
  • Low Pressure Hose – leaking
Learned Zero Ref - Should be reading near (-0.06 psi and 1.48 volts).
It can bias out of tolerance and no issues, but when it nears (-0.30) its on the outer limits of reliable readings.
You will most likely find moisture in the (High Pressure) Hose, this creates a (Pressure Ref) imbalance and also over time it destroys the sensor membrane and it causes it to bias the DPFE electrically.
So if you have a scanner capable of reading the DPFE (Pressure and/or Voltage) PIDs
Compare - KOEO and KOER - Key On - Engine Off / Running
I suspect its not reading in a normal range.
