dapakattack
- First Name
- Daniel
- Joined
- Dec 30, 2020
- Threads
- 5
- Messages
- 398
- Reaction score
- 1,642
- Location
- North Texas
- Vehicle(s)
- 2020 Ranger XLT 4x4
- Thread starter
- #1
Hello All,
Awhile back I posted that I tore the bushing on my passenger side outer tie rod (2020 XLT 4x4). I went ahead and ordered a replacement for KB3Z-3A130-B and also ordered W520213-S440 from VillageFord Parts Upon replacement, discovered that that part does not tighten properly to the knuckle.
* The original tie rod has a 19mm nut that can be tightened down completely to the cast iron knuckle.
* The replacement tie rod has a 15mm nut that bottoms out and does not tighten down even while holding
the hex portion of the tie rod shaft.
* The original tie rod has a white number on it of 38280818 20-269 (see picture)
* The new tie rod has a white number on it of 38222042 20-036 (just as the picture below taken from the
rockauto website
Has anyone else replaced a tie rod without running into this issue? I've also noticed that all the Youtube videos showing suspension work have the Aluminum knuckle and have 15mm tie rod nuts.
Does anyone know if those numbers can be cross referenced to the usual Ford part number? Maybe @P. A. Schilke would know?
I may just end up bringing it in to the dealer and having them figure it out.
Thank you for the help.
rockauto website
