ODBII Auto Start/Stop Eliminator - $129
mike
Hawaii
2019 Ranger Lariat Supercab, Nissan Rogue
The worst was pulling in the laneway and if you hesitated a millisecond putting it into park off she went only to start back up when you put it in park:explode:
THIS! is very annoying. I do get into stop and go traffic, but it seems erratic with how it decides to shut off but it is very consistent in shutting off when I don't want it to when I'm pulling in to my tight garage. With an open-mind, I've never felt that the extra hardware/technology has been anywhere close to worth it.
I'm hard-headed sometimes and feel like I can just train myself to push the button every time but that auto-stop eliminator may be in my future.
VAMike
2019 Ranger Lariat SuperCab
I just turn the truck off and then put it into park. :)
mike
Hawaii
My issue is I pull into a very tight garage. Actually, it's open underneath but there are support poles on the right that are not straight in line. I use that angle to create some door opening space with the other car. And it's also not super deep so I try and pull in as much as possible. Being careful and precise is difficult with the imprecise brakes :) So if the brakes decide that I need to push a lot further down the engine will shut off then start back up as I quickly let up off the brake. Anyway, problem is solved now. I don't need a fancy electronic gadget and just use the first time the engine shuts off as my reminder to shut it off.
MSG W
Kirk
Missouri
2019 Ford Ranger Lariat everything on it but Chrome Package
On the lariat under setting you can disable the auto shut off. I noticed it this weekend.. it does not bother me so I leave my on
Truck2019
Indiana
How does one do this? I have the Lariat as well. Does disabling it affect anything else? Thanks!
t4thfavor
Chance
I'm guessing it comes back on after a key cycle, or else it wouldn't qualify for CAFE points which is the whole point of having the feature.
Truck2019
Indiana
Yep, tried it over lunch. You can turn it off in the menu, but it's the same as pushing the button. Once you turn the truck off and then back on it default's back to start stop being enabled. Frustrating that a feature than many don't like is being forced on the consumer and probably saves little in gas for normal driving that consists of a few stops on the way to and from work.
MSG W
Kirk
Missouri
I will take you at your word I never have tried to turn it off. I only have 1 stop light and 3 stop sign and on drive to work . .. . so it really does not effect me :)
Tracy Bowman
Tracy
My husband doesn’t like it so I turn it off when he is riding with me. It doesn’t bother me at all and I have noticed a small increase in gas mileage with it on. I leave it on when it’s just me.;)
t4thfavor
Chance
Yup. It's isn't a big deal, and improves fuel economy.
The main reason I don't like it is that my Ham radio reboots every time the truck restarts. I'm planning to add a small battery with a large diode inline behind the back seat where the radio is mounted. Should help me to use the Auto start stop feature as intended.
VAMike
That would certainly be annoying :D
