NGK Ruthenium Spark Plugs
For those wondering, unless the aftermarket company that is providing information requiring changing parts like the spark plugs its best to leave it be. Spark plugs seem to be a bit of a pain with vehicles since manufacturers design them with very particular specifications. Even if tuere are similarities between a Motocraft and NGK they will be different enough that problems can arise
Dgc333
21 Ranger Lariat
Ford's have always ran best with Motorcraft plugs.
Ford's like Motorcraft electrical crap best, period.
FWIW, Motorcraft does not make spark plugs. For years they were made by Autolite and more recently by NGK and Denso as some one here mentioned. Even the plugs installed from the factory are not necessarily made by the same company as what Motorcraft sells as replacements and that is true for a lot of parts.
I have always had great service from Autolite plugs in all my vehicles and they will be my first choice for the Ranger when the time comes. I used them in my Ecoboost Mustang and they provided great service until I traded it for the Ranger
Mr Adventures
Mr Adventures
Tyler
Washington
2019 Lariat FX4
If she runs perfectly, why do you need to change them?
Gas mileage is down over the last few months and they’re dirty/oily with dark corrosion built up. Should have clarified: she runs perfectly compared to the NGKs. They can definitely use a change at 67k.
deleriumtremor
Bill
Boise ID
2022 Ford Ranger XLT FX4
The part numbers are interchangeable. Specs are exactly the same between the two. Unless I’m missing something?
You are missing something, if you had the right plug, the engine would run like new.
The service manual already says to change the spark plugs at 60,000
Mr Adventures
Mr Adventures
Tyler
Washington
2019 Lariat FX4
This is what I thought, it depends what dealer you ask. My local dealer said 100k. This is an ongoing debate due to misinformation from Ford. Which is why I suggested at least check at 60k ?
deleriumtremor
Bill
Boise ID
Lol not a helpful reply. Thanks for the thoughtful input.
Sorry you didn't find it helpful. Frankly I am not surprised.
I gave you the right part number a page ago.
If you go to NGK's web site and put the part number you tried in the compatibility search it will say it is not compatible with your vehicle. Try 2019, 2020, 2021, 2022 MY's.
It is always best to go back to 2019 (same engine, as many times these guys don't update their compatibility charts for years they don't think anyone in their right mind will be shopping for the product yet. ).
You will find the number you have (95605) is not compatible.
Then, input the number 94095, use 2019 MY as they still may not have updated their compatibility chart for later model years, as again, they may assume nobody in their right mind will be needing them yet.
You will find NGK 90495 is the part you need.
Then go to Autozone or Rockauto and buy the right plug. They will look nice and shiny, your engine will run like a top and you will KNOW you are getting better performance and MPG, even though in actuality, nothing of substance will have changed.
Oh, and one final piece of advice, check to make sure you have the right part number before screwing around with gap. If it is misfiring, it isn't a .027" vs .031" gap issue. Sheesh.
You caught me on a cranky night. Sorry.
deleriumtremor
Bill
Boise ID
Another factor to consider when you are buying auto parts is the source of supply. Things like spark plugs are favorites for the guys who make knock off parts.
In this ever increasing online supply chain, clone and knock off parts, even some extremely esoteric products you can’t dream might pay to knock off find knock offs in the supply chain.
Mr Adventures
Mr Adventures
Tyler
Washington
2019 Lariat FX4
Update: put NGK 94374 plugs in. They are confirmed fitment for the 2019 Ranger. Still misfires/check engine light. Old stock plugs put back in and now it’s running smooth again. I did check gap of the NGKs and it looks good.
I got another NGK plug because they didn’t have the ford plugs in stock. My truck really does not like NGK apparently…
