Spark Plugs - NGK Equal?
McFly121
Pingree Grove, IL
2020 Ranger
Courier
I'm glad you found the post helpful :) . Factory torque spec is alledgedly 12ftlb. However, being an aluminum head it really depends on the temperature of the engine when you swap them.
If your doing it cold I'd recommend the 12ftlb +/- 10-15deg. If you use the 12ftlb with the motor hot the ceramic on the plugs will likely break when pulling them out.
How's it been running? Do you have any bolt-ons?
So what your saying is on my 2020 ill be fine doing 10-11 ft/lbs on my new plugs..get so many different answers different sorces
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
I used NGK Iridium in my old Sport Trac. For the Ranger I stepped up to NGK Ruthenium on the advice of a guy on another Ranger board who owns a tuning shop. Mine isn't tuned so I stuck with the stock heat range. Runs great.
McFly121
Pingree Grove, IL
2020 Ranger
Courier
Despite In ngk thread I did go oem. I'm just going to probably go between
11-12 ft/lbs seems to be a good range
