RangerOwner86
- First Name
- Johnathan
- Joined
- Sep 16, 2025
- Threads
- 4
- Messages
- 31
- Reaction score
- 123
- Location
- Stony Plain, AB
- Vehicle(s)
- 2023 Ford Ranger Lariat
- Occupation
- Warehouse Supervisor
- Thread starter
- #1
Good day everyone!
I have had my '23 Ranger Lariat since August '24 and it has been a good truck! When I bought it, it did not come with a factory brake controller, which I thought was weird for a truck that came with a tow package. So I asked the dealership to install the Ford brake controller for me before I took delivery. Instead the installed a Curt Spectrum Brake Control 51170. I have not used it yet so I don't know if it actually works or not! Has anyone else used this controller, is it any good?
After I bought my truck I took and bought a pop-up camper weighing maybe 2,000 pounds and it came with non-working surge brakes. The truck towed it awesome, didn't even really notice it was behind me most of the time. I ended up selling the trailer and at the 2026 RV show in Edmonton I am going to be buying a 2026 R-Pod 194.
This trailer has a GVWR of 4,760 pounds, which I doubt I will ever load it up to, hopefully will keep it around 4,000 to 4,200 pounds max with all my gear and food. I will also be bringing with me 3 25L Jerry cans of extra fuel, kept in the bed of the truck, since this thing has such a tiny fuel capacity.
My question is, do I need a WDH hitch? I keep seeing people saying yes I do and I see people saying no I don't. This will be my actual full size trailer I am buying and towing. A lot of my trips will be on the prairies with hills and such, but I will also be doing a trip to BC every year (mountains). I want to be as safe as possible while on the road. I know when I hauled 1,000 pounds of dirt in the bed, the truck really didn't squat that much, but I'm not sure what having around 546 pounds of tongue weight (4200lbs x 13% tongue weight) will do to the truck.
When I was doing all my numbers, I found it interesting as well how the truck is rated to tow 7500 pounds max with a 750 pound tongue weight max, but according to my numbers, my GVWR is 6,050 pounds, the GCWR is 12,500 pounds, which means I could really only legally tow 6,450 pounds. How did they come up with the higher number?
Another question. The truck currently has 45,657 KM's on it, only had standard service (oil change, new tires, filters.) I bought it off a 1yr lease which I assume was doing mostly highway mileage as it had just over 38,000 KM's when I bought it. I put less than 10,000 KM's on a year, so this didn't really bother me. When I start towing, how often should I change my transmission fluid? Is just doing a pan drop and filter change okay or do I need to do it another way? In the spring time when I do my spring oil change, I also plan on changing the fluid in both diff's, the transfer case, change the spark plugs, so that when I start towing I know I've got a fresh tune up. I currently do 2 oil changes a year; one in the fall around October and then one in the spring time around April. I do this because most of my driving is 5KM or under one way, so the engine and fluids never really get up to operating temp. I plan on doing four good trips next year!
My dad is a Ford mechanic, so I have access to a shop (on occasion) with a hoist to do most of the work myself and someone to help me with stuff I can't do, which is always nice!
Thank you for all the help and tips!
Attached is a pic after I bought my truck and the '97 Jayco pop-up trailer I had bought!
