paval3
- First Name
- Val
- Joined
- Apr 30, 2021
- Threads
- 35
- Messages
- 702
- Reaction score
- 1,527
- Location
- Pennsylvania
- Vehicle(s)
- 2021 Ranger XLT Crewcab & 2003 Mountaineer Premier
- Thread starter
- #1
So I stopped by the Ford dealer down the road from where I work. I figured rather than having my yearly inspection, first oil change and tire rotation along with trying to get my genuine ford part keyless entry keypad programmed all in one visit, I'll just try to make an appt for the keyless entry keypad programming and checking the transmission fluid dipstick in one separate visit. You may not have read in another thread where I mentioned that one time (and only one time) in the really cold weather where I didn't let the truck warm up 3 or 4 minutes, I exited my driveway in Reverse, put the truck then in Drive 2H and it wouldn't move (no snow or rain on roads). I then put it in Reverse, wouldn't move. Put in in Drive and 4H and it moved. I was then able to put it in Drive 2H on the fly. So I wanted to get the transmission fluid level checked.
I went to the service desk, said I had two question. 1) How long will it take to program my genuine Ford part keyless entry key pad?
2) Would they check my transmission fluid level on the dip stick? Told them I wasn't capable to slide under the truck and check myself.
Answer I got: Will take 1.2 hour to program the keypad according to computer. BUT, they have never done one so maybe only .5 hour, just don't know.
Yes, they can check the transmission fluid, but it wouldn't be under warranty to just check the dipstick and I would be charged since that would fall under "maintenance"! I told them again what it did that one time and it should be covered under warranty. I was told if they do a full diagnosis (checking for codes) and then checking fluid, yes it would be put under warranty. I said well put it in for service that way then!
