Ace
- First Name
- Ace
- Joined
- Jun 16, 2021
- Threads
- 29
- Messages
- 253
- Reaction score
- 294
- Location
- Raleigh, NC
- Vehicle(s)
- 2021 Ford Ranger
- Thread starter
- #1
Did my oil change last weekend and I usually empty/clean out my oil catch can at the same time. I usually just unscrew the bottom of the can instead of removing the drain plug. But for some reason, I couldn't remove the bottom of the can because it's seized up. I ended up removing the whole unit to see if I can get a better grip but with no luck. I don't have a pair of channel locks that big or a bench vise. So I decided to see if I can purchase a replacement can from Mishimoto. Holy crap! That thing is expensive! So I looked at other alternatives. Wouldn't you know it, I found something similar on eBay for 15 bucks. It seems to be identical to Mishimoto's minus obviously the branding. I also purchased some hose end caps and some hose separator to clean up the installation a bit.
It turned out pretty good I think. I made sure to put a little anti seize on the threads this time to make sure this issue won't happen again.
Any of you guys that have this system run into this issue before?
