Lightforce Switch Faschia
RangerRaptor
Denver
2019 Ford Ranger Lariat (previously 2012 Ford SVT Raptor)
Do the buttons light up at all when activated or when you turn truck lights on?
I had all of my switches custom made (icons and colors). Mine were all blue when the truck was running, but two of them were yellow when turned on, two were green, and two were red.
Zims4x4
2022 Ford Ranger XLT Forged Green
how did any of you guys like this product? is it worth the $$ and time?
Colo_Ranger
2021 Ford Ranger XLT FX4
It was 100% worth the price. If you're looking for an easier solution, the Garmin PowerSwitch doesn't require running wires through the firewall. Its on sale fairly often, but costs more. If you want physical switches, this is the cleanest option.
RangerPNW
Thomas
Santa Fe, NM
Project Manager
I really like it. Anyone that doesn't know what it is would think its OEM. I only have one set of aux lights right now (don't plan to add TOO many more), so this is a perfect option for me. Yeah its a little more work to wire up the lights, but if you've only got a few lights to wire i would go this route.
Zims4x4
Thank you
The_Kings_apostle
Tim
Georgia, USA
2019 Ford Ranger XLT
I order this and a couple of switches. I live in America so it'll be a little while until I get it but I'm trying to plan ahead and learn what's necessary to install these.
Where do you connect these do that the LEDs automatically turn on and off and have enough power to turn on the aftermarket lights?
Anyone know of any videos of how to wire them up?
Colo_Ranger
Each switch has a light for the LED that you’ll have to wire together and connect to a switched power source, I used a splice in the marker light on the fender, but you could use an add-a-fuse in the cab, the owners manual should have a list of fuses and let you know which ones are switched power. As for wiring the lights themselves, the switch should be used to power a relay and the relay should power your lights. If you run your lights directly off the switch, you’ll burn out the switch and possibly start a fire. YouTube has a lot of good videos on wiring up relays.
The_Kings_apostle
Tim
Georgia, USA
Great! Thank you so much for this answer! I've been searching for this information and haven't been able to find it! And thanks for the warning! I would've wired them straight to the lights!
gannbino2001
chris
Nevada
2022 Ranger XLT
Will this fit my 2022 Ford Ranger ?? This look great!
