JB4 Tune (Burger Motorsports)
Psykostevo
Queen Creek, AZ
I tend to see 18-19psi on mine in stock configuration. This is on low octane fuel and @ 5,200ft elevation, reading from an auto agent 2. Not trying to disagree, but curious if there is maybe a different PSI sensor that the auto agent is pulling from? I've pulled up MAP and it tends to follow based on atmospheric pressure to match up to 20psi spikes.
Peak boost will vary based on OAR (Octane Adjustment Ratio). If the car is knock free on your gasoline it will run up to about 19psi peak (not constant). But it you have a low OAR rating it will usually target lower torque output and use the reduced tables for about 14-15psi.
You won’t be seeing that 19.9psi at redline on the stock tune. But you can see that and more with a tune (whether from JB4 or ECU flash)
ColoRanger
Cody
Fair enough, I figure with the low octane fuel I run 85 octane the boost it sees is pretty good. I just didn’t know if maybe it was reading prior to cac showing no pressure loss maybe. It’ll hold 17-18 pretty decent on good pulls. But as you have stated in your other posts, regarding the throttle being closed for “nanny” features you can clearly see it when monitoring the throttle position %, interesting to see.
jlmotox
CA
any updates?
Todd Chapin
Todd
Alexandria
2019 crewcab lariat fx4
Chef
Interested as well.
CharChar
Atlanta, GA
2019 Ford Ranger XLT Fx4
:lipssealed:
Rinn69
N. Central Iowa
Retired USAF MSgt
FlRanger
FlRanger
South Florida
2019 Ford Ranger Lariat
Still waiting for the updated tune.
Grimlock
Greg
Arkansas
2019 Ranger Lariat / 2019 Edge ST
Do we know if this can fix the skip shifting? Im thinking about grabbing this.
FL.ranger
South Florida
Beta version shipped
Sandman Ranger
Pete
Lead Process Engineer
Howd you get your hands on that?
He is OP.
The one working with JB4 to develop.
Waiting for this. JB4 big in VW GTI WORLD for years.
Counting on you OP!
BDUb
Kevin
San Diego, California
2019 Ford Ranger XL 4x4, Magnetic
SUPER LAME!!! ONLY for track use...NOT for sale is CALIFORNIA.
WTH is wrong with California? Cant get jack here. So frusterated with the government micro management.
