- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,512
- Reaction score
- 8,611
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
Wow - You have a book of codes - since most are all (COM) codes i think we need to focus on the other codes first.
The Occupant Class Code - may be just due to all the related FCIM (com) codes - this is the passenger seat mat that trips on the light when occupied. (Airbag)
The Air Inlet Door - Code - Check the wiring above the Glove Box, for the air inlet door actuator, mice entry through this door.
The High Mounted Stop Light - May be bad bulb or light or shorting, if you have the TBC tied into this (disconnect) it for T-Shoot
The Tire Press Code - Could be just a fluke or failing sensor - but not the cause of these errors
The BLIS Modules - now they are not directly coding, other than (Com Errors) however history has shown they will not always hard code, but if you are wire tapped for any lighting off of the tail lights can trigger faults in this circuit.
The main tie in - is that the - CHMSL & Air Inlet door are on the MS-CAN bus, the BLIS Modules are also on that bus - these 2 items are reporting power issues and may be the source of all the faults and shorting out the Can Bus that is transferring across all buses., hence the long list.
But I would check BOTH BLIS modules and connectors, more so the RT Side as it logged the most faults ensure no moisture is inside the assembly as well.
plus since this is a KNOWN bad connection point - check C422 for moisture intrusion or corroded pins.
This connector feeds the BLIS modules
