Intermittent errors with Blind Spot Monitor
This started a couple of days ago and has persisted. It is intermittent but continues to happen and is getting very annoying. What happens is I get an error on the dash for "Blind Spot System Fault" followed almost immediately by a "Cross Traffic System Fault". It will stay there for a bit and then clear itself after a while. And then the cycle repeats. It is not completely regular - meaning it doesn't happen every 30 seconds or every minute or any consistent length of time - but it is consistent enough to occur quite a bit. I just got back from an hour drive and it probably happened 20-30 times during the drive.
A couple of other weird/interesting things happen when this occurs. I have the "cold weather monitor" (snowflake) turned on in Forscan and when this occurs, the snowflake usually appears. Sometimes the temperature readout on the screen will disappear, sometimes not - but the snowflake almost always appears. I've also seen the airbag light come on sometimes when it happens, but that does not happen very often.
I took the taillights out just to see if something had happened to a connection or something - both looked fine other than a lot of dust (I drive a lot of dusty forest service roads)- no damage to the wires - I'm guessing that there may be some mouse damage somewhere - I had a mouse in the truck a while back.
Any ideas for what to look for would be appreciated before I take it somewhere to have it looked at. This is kind of a weird one.....
Also - until I can get this fixed is there a way to turn this off? I haven't seen a setting that turns off blind spot monitoring or cross traffic alerts.
RangerBill
Have you read the DTC codes using Forscan? Knowing any codes will help narrow the problem down.
One other symptom I noticed is that when these errors are displaying the turn signals flash fast - when they are gone they work normally.
Yikes! There are a lot of them - I know the U0422 is nothing to be worried about - that is due to a change in the tire size to fix the speedo - but some of the others look very concerning:
===PCM DTC U0164:00-68===
Code: U0164 - Lost Communication With HVAC Control Module
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Module: Powertrain Control Module
===END PCM DTC U0164:00-68===
===PCM DTC U0422:00-2F===
Code: U0422 - Invalid Data Received From Body Control Module
Status:
- DTC Present at Time of Request
===END PCM DTC U0422:00-2F===
===OBDII DTC None===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC U0232:00-08===
Code: U0232 - Lost Communication With Side Obstacle Detection Control Module A
Status:
Module: Accessory Protocol Interface Module
===END APIM DTC U0232:00-08===
===APIM DTC U0233:00-08===
Code: U0233 - Lost Communication With Side Obstacle Detection Control Module B
Status:
===END APIM DTC U0233:00-08===
===APIM DTC U0256:00-08===
Code: U0256 - Lost Communication With Front Controls Interface Module A
Status:
===END APIM DTC U0256:00-08===
===PAM DTC U0256:00-28===
Status:
Module: Parking Aid Module
===END PAM DTC U0256:00-28===
===PAM DTC U0557:00-28===
Code: U0557 - Invalid Data Received From Front Controls Interface Module A
Status:
===END PAM DTC U0557:00-28===
===PAM DTC U0252:00-28===
Code: U0252 - Lost Communication With Lighting Control Module- Rear B
Status:
===END PAM DTC U0252:00-28===
===BdyCM DTC B124D:02-C8===
Code: B124D - Tire Pressure Sensor
Additional Fault Symptom:
- General Signal Failure
Status:
- Malfunction Indicator Lamp is On for this DTC
- Test not complete
Module: Body Control Module
===END BdyCM DTC B124D:02-C8===
===BdyCM DTC B1115:15-48===
Code: B1115 - High Mounted Stop Lamp Control, Incorrect Current Consumption, Suspect Incorrect Bulb Fitted
- Circuit Short To Battery Or Open
Status:
- Test not complete
===END BdyCM DTC B1115:15-48===
===BdyCM DTC U0256:87-08===
- Missing Message
Status:
===END BdyCM DTC U0256:87-08===
===BdyCM DTC U0252:87-08===
- Missing Message
Status:
===END BdyCM DTC U0252:87-08===
===SODR DTC U0146:00-28===
Code: U0146 - Lost Communication With Serial Data Gateway A
Status:
Module: Side Obstacle Detection Control Module - Right
===END SODR DTC U0146:00-28===
===SODR DTC U0100:00-28===
Code: U0100 - Lost Communication With ECM/PCM A
Status:
===END SODR DTC U0100:00-28===
===SODR DTC U0101:00-28===
Code: U0101 - Lost Communication with TCM
Status:
===END SODR DTC U0101:00-28===
===SODL DTC U0146:00-28===
Status:
Module: Side Obstacle Detection Control Module - Left
===END SODL DTC U0146:00-28===
===SODL DTC U0100:00-28===
Status:
===END SODL DTC U0100:00-28===
===SODL DTC U0101:00-28===
Status:
===END SODL DTC U0101:00-28===
===FCIM DTC B11F0:15-08===
Code: B11F0 - Air Intake Damper Position Sensor
Status:
Module: Front Controls Interface Module
===END FCIM DTC B11F0:15-08===
===FCIM DTC U0140:00-48===
Code: U0140 - Lost Communication With Body Control Module
Status:
- Test not complete
===END FCIM DTC U0140:00-48===
===FCIM DTC U0151:00-48===
Code: U0151 - Lost Communication With Restraints Control Module
Status:
- Test not complete
===END FCIM DTC U0151:00-48===
===FCIM DTC U0155:00-48===
Code: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
Status:
- Test not complete
===END FCIM DTC U0155:00-48===
===FCIM DTC U0253:00-48===
Code: U0253 - Lost Communication With Accessory Protocol Interface Module
Status:
- Test not complete
===END FCIM DTC U0253:00-48===
===FCIM DTC U0452:82-48===
Code: U0452 - Invalid Data Received From Restraints Control Module
- Alive/Sequence Counter Incorrect/Not Updated
Status:
- Test not complete
===END FCIM DTC U0452:82-48===
===TRM DTC U0140:00-28===
Status:
Module: Trailer Module
===END TRM DTC U0140:00-28===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===TCU DTC None===
Module: Telematic Control Unit Module
===END TCU DTC None===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===RCM DTC B00A0:68-08===
Code: B00A0 - Occupant Classification System
- Event Information
Status:
Module: Restraint Control Module
Freeze Frame #1:
-TOTAL_DISTANCE: 115256 km - Total Distance
Freeze Frame #2:
-TOTAL_DISTANCE: 116913 km - Total Distance
===END RCM DTC B00A0:68-08===
===RCM DTC U0100:00-08===
Status:
Freeze Frame #1:
Freeze Frame #2:
===END RCM DTC U0100:00-08===
===RCM DTC U0112:00-08===
Code: U0112 - Lost Communication With Battery Energy Control Module B
Status:
Freeze Frame #1:
Freeze Frame #2:
===END RCM DTC U0112:00-08===
===RCM DTC U0140:00-08===
Status:
Freeze Frame #1:
Freeze Frame #2:
===END RCM DTC U0140:00-08===
===RCM DTC U0253:00-08===
Status:
Freeze Frame #1:
Freeze Frame #2:
===END RCM DTC U0253:00-08===
===RCM DTC U0557:82-08===
Status:
Freeze Frame #1:
-EVENT_TIME: -198345803 s (Wed Jul 15 16:19:10 2026) - Event time
-TOTAL_DISTANCE: 118494 km - Total Distance
Freeze Frame #2:
-EVENT_TIME: -198178412 s (Fri Jul 17 14:49:01 2026) - Event time
-TOTAL_DISTANCE: 118774 km - Total Distance
===END RCM DTC U0557:82-08===
===PSCM DTC None===
Module: Power Steering Control Module
===END PSCM DTC None===
===SCCM DTC U0100:00-08===
Status:
Module: Steering Column Control Module
===END SCCM DTC U0100:00-08===
===SCCM DTC U0140:00-08===
Status:
===END SCCM DTC U0140:00-08===
===SCCM DTC U0146:00-08===
Status:
===END SCCM DTC U0146:00-08===
===IPC DTC U0100:00-08===
Status:
Module: Instrument Panel Control Module
===END IPC DTC U0100:00-08===
===IPC DTC U0232:00-08===
Status:
===END IPC DTC U0232:00-08===
===IPC DTC U0233:00-08===
Status:
===END IPC DTC U0233:00-08===
===IPC DTC U0256:00-08===
Status:
===END IPC DTC U0256:00-08===
===IPC DTC U0401:00-08===
Code: U0401 - Invalid Data Received from ECM/PCM A
Status:
===END IPC DTC U0401:00-08===
===IPC DTC U0401:82-08===
Status:
===END IPC DTC U0401:82-08===
===IPC DTC U0557:81-08===
- Invalid Serial Data Received
Status:
===END IPC DTC U0557:81-08===
===IPC DTC U0557:82-08===
Status:
===END IPC DTC U0557:82-08===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===IPMA DTC U0100:00-28===
Status:
Module: Image Processing Module A
Freeze Frame #1:
-EVENT_TIME: -200686557 s (Thu Jun 18 14:06:35 2026) - Event time
-MODULE_VOLTAGE: 12.0 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 22 °C - Outside temperature
-ECU_POWER_SUPPLY: 11.7 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 27 °C - ECU Internal Temperature
===END IPMA DTC U0100:00-28===
===IPMA DTC U0101:00-28===
Status:
Freeze Frame #1:
-ECU_INTERNAL_TEMPERATURE: 28 °C - ECU Internal Temperature
===END IPMA DTC U0101:00-28===
===IPMA DTC U0140:00-28===
Status:
Freeze Frame #1:
===END IPMA DTC U0140:00-28===
===IPMA DTC U0418:86-28===
Code: U0418 - Invalid Data Received from Brake System Control Module A
- Signal Invalid
Status:
Freeze Frame #1:
===END IPMA DTC U0418:86-28===
===IPMA DTC U0422:82-28===
Status:
Freeze Frame #1:
-ECU_POWER_SUPPLY: 11.8 V - ECU Power Supply Voltage
===END IPMA DTC U0422:82-28===
===IPMA DTC U0429:86-28===
Code: U0429 - Invalid Data Received From Steering Column Control Module
- Signal Invalid
Status:
Freeze Frame #1:
===END IPMA DTC U0429:86-28===
RangerBill
Look in the menus under Driver Assist to turn BLISS and Cross Traffic off.
RangerBill
Status:
- Test not complete
Status:
Status:
Status:
Status:
Status:
Status:
Status:
Status:
- Test not complete
Status:
- Test not complete
- Missing Message
Status:
- Missing Message
Status:
Status:
Status:
Status:
Status:
Status:
Status:
Status:
Status:
- Test not complete
Status:
- Test not complete
Status:
- Test not complete
Status:
- Test not complete
Status:
- Test not complete
Status:
===ABS DTC None===
===TCU DTC None===
===RTM DTC None===
- Event Information
Status:
Freeze Frame #1:
Freeze Frame #2:
Status:
Freeze Frame #1:
Freeze Frame #2:
Status:
Freeze Frame #1:
Freeze Frame #2:
Status:
Freeze Frame #1:
Freeze Frame #2:
Status:
Freeze Frame #1:
Freeze Frame #2:
Status:
Freeze Frame #1:
Freeze Frame #2:
===PSCM DTC None===
Status:
Status:
Status:
Status:
Status:
Status:
Status:
Status:
Status:
Status:
Status:
===GWM DTC None===
Status:
Freeze Frame #1:
Status:
Freeze Frame #1:
Status:
Freeze Frame #1:
- Signal Invalid
Status:
Freeze Frame #1:
Status:
Freeze Frame #1:
- Signal Invalid
Status:
Freeze Frame #1:
Have you checked for water/moisture in either taillight and its corresponding BLIS module? You might want to remove each BLIS module from the taillights and check for corrosion on the module and in its connector. Many of your DTCs are communications related and a corroded BLIS module or wiring can cause problems with the communications buses.
I took one of the BLIS modules out (the drivers side) and it was VERY clean - the connector to the taillight was very dusty but the BLIS module connector looked great - I did not remove the connector though.
RangerBill
You could also try unplugging both taillights and clear all the codes. Then rescan to see what codes come back.
RangerBill
You need to look at both taillights and their BLISS modules.
Grandaccess
Binghamton, N.Y
Computer Consultant
I have something like that going on too, I figured it was because of my bull bar blocking it, I click ok and move on?
Grandaccess
Binghamton, N.Y
Computer Consultant
I had one replaced by a body shop and he said they couldnt get the error to go away, I dont know what program they had, I dont want to spend the money at the dealership for them to trouble shoot it, I have forscan I just dont have the time :(
RangerBill
I believe that you have to enter the VIN number in the BLIS module if a new one is installed. Forscan should be able to handle that.
I took it out for a hike today and for now, I've disabled the blind spot monitoring and cross traffic functions. I needed to disable those when it wasn't displaying the errors - once I did that it seems like the warning stopped. I could see the disabled icon in the dash appearing and disappearing (the issue is still occurring), but at least I'm not getting bugged by all the warnings over and over and over. I will try and dig into this tomorrow or Monday to see if I can see anything.
Cabose-1
Eli
Student
Obviously a module is on the fritz. Question is which one. Check grounds, one part of the system is wrong it makes everything connected to it act wonky. You will have to find a wiring diagram to see what all the devices have in common and start the search for individual modules. With fords it is a long and learning process. Maybe a unplugging until one of them makes the codes go away. What i used to do for ford vehicles.
Good luck
Good luck
I've had mice in the cab (I can see the damage from them) - I'm much more concerned that there is some wiring damage somewhere rather than a module on the fritz.... Fingers crossed I'm wrong, but time will tell. I'm no wiring expert so this may end up at a shop for this.
