Installed 589 mount with Superwinch on Tremor
JetEngr19
Oklahoma City
2019 Ford Ranger, 2016 Jeep Wranger
you sure about that? ive read it can be clocked a bit just not as much as the zeon
Yes, you can clock the Warn Evo. I’ve clocked it 90 degrees. I saw a video on YouTube of someone clocking it 180 degrees.
Edit:
Rhino
jacob
idk help!
professional anime watcher!
Edit:
That’s what I figured since I’ve seen them in arb bumpers before
OneMore
OneMore
Walter
Bay Area, NorCal, CA
2022 Ranger Lariat Tremor
Did this bracket come with the kit?
A bracket did come with the 589 winch mount. I didn't use it as it wouldn't work with the Tremor's extra electrical switch box. I modified the bracket that holds the Tremor electrical box to mount the winch control box.
OneMore
OneMore
Walter
Edit:
Well I guess Warn needs to hire more informed sales staff.
Colo_Ranger
Can you send me a picture of the mount and would you be willing to part with it?
OneMore
OneMore
Walter
Here are a few pictures of truck all back together.
I like this mount as you use the stock bumper. No extra length or weight of aftermarket bumpers. As well as less $$$ spent.
ACC relocation bracket is from Cali Raised, about $30, well worth it.
https://caliraisedled.com/products/2019-2021-ford-ranger-acc-radar-relocation-bracket
The winch opening I blocked off with a piece of Kendex.
It is held in place by the round Factor 55 Loop Guard.
This will keep the sun and rain from getting to the winch rope.
It is not centered as this is where the rope coil ended up on the drum.
You really need to know what you are looking at to even know there is a winch installed.
Colo_Ranger
Would you mind getting the part number off that ford bracket?
OneMore
OneMore
Walter
Sorry. Everything is done and bolted in place. Very difficult to remove winch control box with four 02 gauge wires attached.
Ford parts department should be able to provide number.
This is the bracket that the wire connection/fuse box is bolted to for a Tremor.
OneMore
OneMore
Walter
Here are some pictures of the 589 winch control bracket.
They would probably sell you just a bracket if you gave them a call.
Colo_Ranger
Sadly, Ford has Tremor specific parts locked down and, even with a Tremor VIN, they couldn't find the part. I'd need a part number. No worries, I will find it another way.
Rhino
jacob
idk help!
looks good how much do you think the front end sagged down with adding the extra weight?
OneMore
OneMore
Walter
I did before and after measurements. No winch=37 3/4, after install= 37 1/4.
So only a 1/2 inch drop. But you will easily feel that extra 100+ pounds on the front.
Congratulations on your new Ranger arriving.
Looks like you have lots of cool projects lined up.
Rhino
jacob
idk help!
that makes sense but not to bad of a sag tbh but you also have beefier front suspension then my truck
and thanks! im pretty excited to start a new light weight and simple build this go around instead of a crawler build haha
