- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,657
- Reaction score
- 8,922
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
From factory - the Approach (Perimeter) Entry/Exit lighting is disabled.
Someone has played with Forscan and actually I did not notice that this was a configurable option.
That would be an annoying option as well as put a strain on the battery.
I suspect some of these lines might be altered:
So, this also may apply to the F-150 (if you want to disable) that truck as well
I would check the following As-Built Data lines as I think these are altered from the factory data.
BCM
726-55-01 - Factory -0000-0000-0083 - Altered (x1x1-x1x1-x1xx)
1=Enable/ 0=Disable
Feature Configure Approach Detection -Position 1 through 5
726-55-02 -Factory -0000-0000-0084 - Altered (x1x1-x1x1-x1xx)
1=Enable/ 0=Disable
Feature Configure Welcome Mat 1 through 5
726-56-01 - Factory -0000-0000-0185 - Altered (x1x1-xxxx-xxxx)
1=Enable/ 0=Disable
Feature Approach Detection & Welcome Mat Int Value
BCM
1=Enable/ 0=Disable
1=Enable/ 0=Disable
1=Enable/ 0=Disable
