- First Name
- Steve
- Joined
- Jul 1, 2021
- Threads
- 84
- Messages
- 5,868
- Reaction score
- 29,236
- Location
- Fishersville, Va.
- Vehicle(s)
- Previous 2021 Ranger, Now 2019 Ford Expedition
- Occupation
- Navy Vet., Retired Police Sgt., Grumpy Old Senior Citizen
- Thread starter
- #1
Don't like the strap on or clip on tow mirrors available. and although I admire the new mirrors coming out of Australia, a $1000 price tag is a bit hard to eat.
I have been playing with stuff I had around the garage and a $20 buck mirror and think I came up with a removable mirror, just leaving a small bracket attached to the bottom of the factory mirror.
Pic's show the aluminum pieces I used and the mirror bought on Amazon. The angle piece is from a length of 1 inch x 1 inch x 1/8 inch thick angle, and the flat is cut from a length of 1 inch x 1/8 inch flat stock. I left it at 8 inches in length for extra mounting holes if needed.
The angle piece is 3 inches long, and will be attached permanently to the bottom of the factory mirror.
The mirror, attached to the flat stock will be removable when not in use, so the only permanent addition to the Ranger will be the angle bracket.
Holes in bracket/flat stock attachment will use 1/4 x 20 hardware. Holes were drilled offset so right/left mirrors don't get mixed up.
The mirror has a ball/socket that is tightened down with 2 screws. When taken on/off/on/off. the mirror should hold its original position/angle so I won't have to re-adjust it every time.
Pics posted give some idea where I'm at now....have to smooth out the metal edges, paint, and mount to the factory mirror bottom. Going to mount the bracket using high strength 3M trim tape, along with two #10 x 24 machine screws/lock nuts.
Entire assembly only weighs 11 ounces, so hopefully won't effect the factory mirror.
Will post more pics as I finish, if anyone is interested.
