Heat crack on windshield!
Typically what they would do at the dealer is run a fine tip ballpoint along the crack. If there is a chip the pen hangs up. If not it’s a stress crack. Think it is a year on that for factory as mentioned.
Another thing you could try is vacuum repair. They use cyanoacrylate glue and vacuum to fill the crack. Sometimes it works and other times crack continues.
If you do get it replaced insist on factory glass, not aftermarket
MountainGoat
MountainGoat
Missouri
2020 Ranger XLT Sport 4x4
Another thing you could try is vaccine repair. They use cyanoacrylate glue and vacuum to fill the crack. Sometimes it works and other times crack continues.
Yeah regarding the factory glass my quote was "without Ranger etched into the glass for availability" so most likely a knockoff.
JesseS
Jesse
NorCal (Roseville)
My RV has a 108" windshield :shock: so I always carry the no deductable glass replacement coverage as it's $2K to replace, also carry that on all my POV's, it's only a few bucks extra and well worth it.
Rhino
jacob
idk help!
professional anime watcher!
I parked my truck outside to wash it and by the time I was done I had a crack on the windshield! What are my chances of getting this fixed under warranty? The truck is always garaged and if it isn't I always open a window in this heat. I guess my windshield can't handle having the windows up for ~45 minutes to get a wash. It was only like 92 this morning too, not 100 like earlier in the week.
my guess is you had a small crack in the windshield and it eventually split because i live in the same state and my truck has been outside for about two weeks now since i ride my bike more and i dont have a crack
MountainGoat
MountainGoat
Missouri
I think it was the cold water hitting the hot glass.
Rhino
jacob
idk help!
tbh it could be a mix of both i had that happen with my tacoma randomly i think last year? it was hot and i washed it and drove it into work and then came out to it having a crack
DakotaGuy
Tom
Black Hills, SD
2022 Ranger SuperCrew XLT Tremor
Run a ballpoint point pen on the whole crack. If it hangs up at any point then they will not warranty it plus if it has over 12k miles.
I believe this is correct. Years ago I had the same thing happen on a vehicle and I thought it was due to stress, but on closer inspection they found a tiny chip right on the edge of the glass that a temp change caused a run. I had to use insurance.
Squatchranger
Orlando
19 ranger lariat
My comp is $1000, that's how I got my insurance down. At this point I'm going to get a price and maybe leave it, see if it doesn't get bigger. At least until the next hail storm...
Doesn't seem like the case here. Is the windshield extra expensive due to the lane-keeping sensors, etc?
It would be yes, florida law makes it zero deductible cause as goat said it is a safety issue but not all states do
Squatchranger
Orlando
19 ranger lariat
Motorpsychology
Prescott, WI
Vagabond
