FX4 vs 4x4 ground clearance
stufus
stufus
Maine
2020 Ranger XLT, 302a, Technology Pack, FX4
Follow up question. Is the ground clearance measured at the control arms? The rear shocks? Just curious if it is solely dependent on tire size.
Does the Tremor have more ground clearance solely because of the larger tires or does the suspension play a role in this?
seanellaz
Sean
Tucson, AZ
Healthcare
Am I missing something both tires are 65/17 so same height. The Width is the big number and it has nothing to do with height. So they should both be the same height unless one has different suspension under it.
The "65" means the tire is 65% as tall as it is wide. Wider means taller. Going to a 70 series will make for taller tire at same width. Some sports cars (and some trucks) have big wheels and tires that look like black rubber bands around the wheel. This is a picture of a 354/25- 20 tire . It is 354mm or about 13" wide. It is 25% as tall as it is wide, 88.5mm or 3.4 inches tall. This is a HORRID setup for anything but racing on smooth pavement. Of roading it will beat your teeth out, and have ZERO flex for traction on rougher terrain. Pretty sure you can go with at least a 265 or even 275 /70 -17 tire to get plenty of lift which still fits fine in the wheel well.
halligan1201
Byron, IL
2020 Ranger
Emergency Management
It's measured at the diff. Tremor has taller tires and an altered suspension that gives it a factory lift if you will. Different control arms in front, different shocks and springs in rear. Between the tires and suspension, it's still under an inch for the increase - takes it to 9.7 clearance.
At the lowest point, usually the rear diff.
The Tremor does indeed have taller suspension, however that alone won't raise the diff. Tires need to be taller to do so. And taller suspension supports taller tires.
stufus
stufus
Maine
Just a follow up in case anyone's interested. Since tire size is not standardized and is manufacturer / model dependent, here are the actual sizes for the various OEM tires on 4x4 Rangers.
16:
4x4 - Bridgestone Dueler H/T - P255/70R16
Tread width - 7.1 in Diameter - 30.1 in
17:
4x4 - Bridgestone Dueler H/T - P255/65R17
Tread width - 8.1 in Diameter - 30.1 in
FX4 - Hankook Dynapro AT-M - P265/65R17
Tread width - 7.7 in Diameter - 30.7 in
TREMOR - Continental General Grabber - P265/70R17
Tread width - 7.2 in Diameter - 31.6 in
18:
4x4 - Bridgestone Dueler H/T - P265 / 60R18
Tread width - 8.3 in Diameter - 30.5 in
FX4 - Hankook Dynapro AT-M - P265 / 60R18
Tread width - 7.7 in Diameter - 30.5 in
