Ranger 4X4 vs 2WD Height
NoXiDe
GA
GT350R
Does the ability to get into the pickup change? I'm referring to someone who has mobility issues. In other words, is a 4X4 taller than the 2WD in reference to the ground and the chair. I've searched and cannot find the stats.
Thank you in advance
machinist85
n/a
n/a
The 2WD and the 4WD have the same suspension and ride height. Keep an eye out if you're looking at used 4wds. Because some of them might sit higher if it has a leveling kit installed.
NoXiDe
GA
GT350R
Is the leveling kit a OEM add-on? Are we referring to the ability for the trailer hitch to level? This would have the towing capacity add-on.
machinist85
n/a
n/a
The leveling kit is aftermarket. It just lifts the front up to sit level with the rear. It's mostly just for looks. But they're pretty popular.
Bludrok
Acampo, California
www.ranger5g.com
They also help with clearance issues for oversize tires.
As Don said though, it only matters if looking at a used Ranger. If you are buying new, it would be very unlikely to have a leveling or other lift kit installed.
