Fuel Filter Replacement Issue
coffeefishpizza
New Zealand
2020 Ford Ranger Wildtrak 2.0L
Hi there,
About to replace my fuel filter and I’ve noticed the WIF sensor block on top has an extra piece that’s clipped on the a fuel line. Can’t find any videos that have this extra piece. Any ideas what it is or how to go about removing it?
TIA
Hi there,
TIA
It looks like you simply - release the zip tie (it has a release tab)
and then
unclip the safety from the tube end - just be careful as - plastic is brittle (heat aging)
and if you unable to get the zip tie to release - repeat the same for the bigger tube
or if the zip tie will release - just release it and they pry up - at the threaded stud to pull it off.
once they are free - the part that is closest to the connector - is just fitted over the stud.
Basically under that - arm (record player) is a nut that is holding the module down and that arm is a secondary holding arm to keep the fuel line from backing off the fitting (a lock)
Its fitted over the stud - that the nut is on (friction fit-to the threads)
