Ford Ranger IV 2020 - No OBD connection
rokas
Lithuania
Ford Ranger IV
Opened the module housing. This is what I found. There was definitely some kind of short caused by the housing touching the board.
RangerBill
Does it work with the cover off?
At this point:
I would check - with PB Start (Attempt) - (Helper Required)
1. Check the Starter Relay - Coil - Power and Ground - are they being applied
2. HS1 - Can Bus activity (Does it fluctuate?) when the start signal is being applied - it should fluct slightly around the 2.5 volts (pressed) and then become stable after release
3. Does the (Check Eng) light - come on at key on
Note: since this has had airbag deploy - the BCM and RCM maresety have a (Crash Event) locked into memory - that may be preventing the start, the BCM should be able to reset, now will Forscan allow this (IDK) may require FDRS (for that deep of a level) the RCM however may need a replacement (or a bench level) reset - I would get com first to see what is being picked up by the RCM (before) we condemn it.
The Good - You have access to FDRS
The BAD - It requires a J2534 Passthrough adaptor - for use - the basic Forscan adaptors will not work. My Top-Don scanner has the adaptor (with it) and have used FDRS using this adaptor. The cheapest (non Ford) adaptor (adaptor only) that I know of is the Mongoose.
Being that the PCM does show damage - it actually does not look like that's actual (Circuit) burn as those appear to be standoff support for the board and I do not see any circuit trace - so impact damage (yes) actual short (IDK) - mainly only seeing a discolored board not melted etc. and yes it may work (if the cover is pulled up) taking the stress (flex) off of the board.
Another Curiosity Question.
The picture of the truck - along with the GWM (Salvage) pic:
Is this your truck or salvage truck pic?
I dug deeper into the board and i think that those pins are actually power and ground feeds for the board - I can see 4 sets in the pic.
And I think this set may be the (feed for the 5-Volt) VREF circuit (step down regulation) as well as the internal 3.3 volts for the processor power as this would explain why the PCM appears dead as far a (Com) its not waking or booting up.
It may be worth a try and see if it will boot fully with the cover not touching the pin, you will still need a pcm, but at this point its just a test (how far can you get)
rokas
Lithuania
Ford Ranger IV
At this point:
This is the truck I bought from the dealer as is.
rokas
Lithuania
Ford Ranger IV
Nothing changes with the PCM connected when the cover is not touching the pins. With the PCM plugged in, I probed those four sets of pins, and each pin shows 0.01 V.
Then I suspect they may all be grounds:
PCM - Disconnected
Each Pin to - Case
Each Pin to - Ground Pins on the connector
I suspect you will find continuity
rokas
Lithuania
Ford Ranger IV
I took the module to an ECU repair shop. After inspecting it, they concluded that the ECU is currently dead. They will investigate further and see if it can be repaired. I'll post an update once I have more information.
noted
rokas
Lithuania
Ford Ranger IV
The processor (or one of the processors) has been shorted and is no longer working. I was advised to consider two possible solutions:
1. Buy a used PCM, resolder the processor onto the faulty PCM, and see if the module becomes operational. If it does, then pull all the data and clone it to the second-hand PCM (after resoldering the working processor again).
2. Buy a used PCM and attempt to program it to the car. However, there may be issues with the immobilizer (PATS). I am not sure what software or hardware they have, but I was informed that it might work-or it might not.
