- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,482
- Reaction score
- 8,549
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
I am confused as to what you are checking - 3- > 3
I am wanting to know (using a meter) and this EXAMPLE of a GWM - not exact part number
Front DLC - Pins 1 through 16
Where do they pinout (Here)?
This way I can determine if the GWM you have will power match your wiring connector C2431 or someone has swapped in a wrong part number GWM.
We can use that information - to see what pins here (in this example only) match up to your actual harness - this will also show by DLC to these pins - show where the data loss is at.
It will also be a good idea to contact a local dealer and find what part number - should be installed (Vin # - match)
So starting at Pin 1 on the DLC side - do you have continuity to any pin on the back side and continue for each pin - Pin 2 - to all of these - is there continuity?
