Ford Performance 4WD Leveling Suspension Kit
LevittownFordParts.com
Gold Sponsor
Benny
New York
All Ford's
Hey, Benny, I am strongly considering this to replace the lift kit I am currently running. In regards to the rear, there are no blocks to lift the truck - does this mean the rear maintains factory ride height?
Hi Justin,
That would be correct. The kit is more of a leveling kit than a lift kit. I assume blocks can be added afterwards and with the adjustable front height it can be dialed in but the maximum additional front height from stock is 3".
-Benny
FP has teamed up with Fox to bring you an adjustable Suspension kit for your 4WD Ranger and we want to bring it to you at the best possible price.
Some product highlights:
  • Fits 4WD models
  • Shocks feature precision impact extruded aluminum bodies that increase cooling capacity and are rust resistant
  • Front coil-overs feature top quality racing coils selected to deliver the optimal spring rate
  • Levels truck front-to-rear
  • Improves front approach angle: 34.8 deg. vs. 28.7 deg. stock
  • Improves breakover angle: 23.8 deg. vs. 21.5 deg stock
  • Vehicle-specific upper front mounts include a composite bushing that isolates noise and vibration
  • Locking, spring preload rings allow easy front ride height and preload adjustments
  • Provides a comfortable on-road ride and predictable off-road handling in even the toughest conditions
  • Easy bolt-on installation with no other modifications required
  • Proudly Made in the USA
Full Product Details Can be found here https://www.levittownfordparts.com/sku/m-18000-r.html
If your interested please be sure to PM us for a code and let us know if you have any questions,
-Benny
The before pic looks like the rear has been lowered...what gives?
Gold Sponsor
Benny
New York
All Ford's
I think FP wanted to accentuate the front end lift, You can see from the attached release Doc the photo is directly from them.
-Benny
HenryMac
Mech. Engineer - Retired
They used the computer generated model for the before photo that is generated on the shop.ford site. Every truck configuration looks nice and level there.. unlike every truck that rolls out of the factory.
Or as it states on the site: "Representative exterior image shown. Actual exterior may vary. See your dealer for details"
https://shop.ford.com/build/ranger/?vhptid=fv-2722-vhp-ranger-ctrl:billboard:slide0:na:ford ranger#/config/Config[|Ford|Ranger|2020|1|1.|101A.R1F..J7...914.53R.99H.SAB.AWD.44U.RETAIL.XL.41H.]
Pathung
Patrick
Northern California
I'll take a code, too, for your Performance suspension system... THANK YOU! Good till Monday?
Willcuts93
Matt
Boerne, TX
'11 Flex '19 Ranger
Technician
For those that have ordered if you would allow us to use your truck pictures for True before and after photos we would greatly appreciate it!
Thanks,
Benny
I will post pictures as soon as i get it. Tracking number says Wednesday.
