Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
2019-2022 Ford Ranger 4WD Bilstein 5100 Adjustable Leveling Shock Kit 19RNGR4WD
Highlights:
The 2019-2022 Ford Ranger should not be trusted to handle the toughest of off-road trails. If you need something with better performance, up to 2.5" of front height and the capability to handle 1" of rear height, a Bilstein B8 5100 Adjustable Leveling Shock Kit will not disappoint you. These front and rear shocks are the perfect replacements for the stock leveling components and come backed by Bilstein's legendary quality and performance. The Bilstein B8 5100 shocks are built from scratch to offer your Ranger a very defined experience. An adjustable front height from 0 to 2.75" allows you to raise the Ranger to your liking and fit larger off-road tires. This increased height and potential new tires help protect your Ranger from off-road obstacles and creates a better driving experience out in the dirt. The specialized valving, high-quality piston and other great components of these shocks provide excellent off-road performance, increased wheel travel, better handling, improved towing control, and a fade free performance!
Features Front & Rear Components w/ an Easy Insall
The Bilstein Ranger 5100 Shock Kit replaces your stock OEM coilover and shock suspension with better components. The 5100 front and rear shocks are built around a monotube, nitrogen gas-charged design for fade-free performance. Each shock uses self-adjusting deflective disc valving, which adapts to different road conditions and provides excellent response in almost any application. The shocks' digressive piston adapts to changing road conditions. The smooth body of each shock is made out of heavy-duty steel and features a 46mm diameter build for a strong shock. A zinc-plated finish and a Triple-C coating adds a great look. The front shocks use snap-in grooves allow you to make height adjustments between 0 and 2.5". When collapsed, the front shock reaches 14.59" and 19.26" when fully extended. The rear shock reaches 15.55" when collapsed and 24.71" when fully extended. Bilstein includes all necessary installation instruction and hardware.
Fitment: 2019-2022 Ford Ranger 4WD & RWD.
Highlights:
- Complete set of four Bilstein 5100s
- Includes front struts capable of up to 2.5" of leveling
- Rear shocks provide enhanced rear-end stability
- Gas-charged monotube internal design
- Steel bodies with zinc-plated finish
