Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
In stock, on sale and ready to ship for anyone in the market for a level kit.
2019-2021 Ford Ranger FactionFab 2.5" Leveling Spacer Kit FFA1.10199.1
Highlights:
While leveling kits are usually a costly investment, it doesn't always have to be this way. If you want to get rid of some rake while adding clearance for larger tires on your 2019-2021 Ford Ranger, all you need it FactionFab's 2.5" leveling spacers. These spacers are made out of high-quality billet aluminum with coated steel studs and flared nuts. The kit also includes a prevision for the factory locating pin. Each set of spacers easily bolt on between the factory top hat and the frame without any permanent modifications, making them a hassle-free upgrade for your Ranger build. The FactionFab leveling spacers come standard with a black anodized finish for a great look. High-Strength Billet Aluminum Construction with Black Anodized Finish
While the new ride height and tire clearance of your 2019-2021 Ford Ranger looks great with FactioFab leveling spacers, you'll love the long-term reliability from its extremely strong and practically impervious to corrosion. The spacers are made entirely out of high-quality and high-strength 6061-T6 billet aluminum that's precisely CNC machined for a perfect fit on your Ranger. Each of the coated steel studs are pressed into the billet body and are coated to prevent corrosion. The studs line up perfectly with the holes in your truck's upper strut mount, and FactionFab includes coated flared nuts for installation. The spacers are topped off with a Type 2 hard anodized, black finish that looks great and helps them blend in with the rest of your truck.
Fitment: 2019-2021 Ford Ranger
Install Instructions: check out FactionFab's install instructions here.
Highlights:
- Provides extra ride height with no hassles
- Easy, drop-in installation
- High-strength billet aluminum
- Steel mounting studs and nuts
- Black anodized finish
