Ford Pass Update
I just got it for IOS, if you (swipe up and right) to close out open screens, the Ford Pass App will reopen as a new refreshed page. In case you are having issues of not getting all the tabs to show data.
I had to refresh mine when first opened - it froze up
FYI: The IOS Version is 5.0.0 for the New App.
As someone stated above - I do not see a way to (Refresh) Location and Health, like the previous version - Swipe Down & Hold
I am sure its available we just have to figure out how - but now we need to monitor how often the Ford Pass - Checks for Updates on the Truck, is it going to be More / Less / Or Same
I am talking about that startling Waste Gate Actuator - Powering while you are in the garage and under the truck when it does it.:shock:
Loweredon33s
Baltimore
2021 Ranger
Performance person
Scares the snot out of my balloon knot every time that happens while I'm under there ?
Mine is totally quiet on this turbo. The previous one was like fingernails on a chalkboard!
JJG
KY
2019 Ranger Lariat Crew Cab
Currently there is no way to add service entries. Past history is there but cannot add new.
Good Catch, I do see it either.
However, the web-based side of it still has the (Add Record) Tab (On-Line- Version)
Waxthis
Eric
2020 Ranger XLT FX4
Controls Tech
ford.com.support
It is the same website you use for Sync & Map Updates
FYI...Website no longer works either. Tried for 3 days with the same error..
"Oops! Something went wrong adding your entry. Please refresh and try again later."
Waxthis
Eric
2020 Ranger XLT FX4
Controls Tech
I was able to get to service and add a record by logging into Ford.com and getting here: https://www.ford.com/support/service-history/
Yip, went through the whole process and
Yip, did the exact process multiple times and keep getting " "Oops! Something went wrong adding your entry. Please refresh and try again later." What browser are you using?
Bah, I've never been able to upload the update XML file and often find the billing site broken. =(
I'm using Chrome but I bet it's some stoopid authentication token screwing your access up. I don't know enough on how to fix that.
I don't think you're doing anything wrong and 100% believe your error. =(
screenshot from Ford.com
Waxthis
Eric
2020 Ranger XLT FX4
Controls Tech
Chrome here also, I've tried Firefox, both normal and private mode also. I'm thoroughly convinced it's the Russians!
Dgc333
21 Ranger Lariat
FWIW, I changed my oil Sunday and updated on the main site with no problems. Ford Pass shows that entry today.
