Ford official tune?
jeepwranger
pittsburgh
'16 wrangler
T
This is the same reason a Corvette engine, geared appropriately (never mind issues of getting it moving due to transmission issues), could pull a semi down the road just fine...again, never mind durability or fuel consumption.
I know I wouldn't want to be sitting behind it when the light turned green.
ben8jam
Ben
Los Angeles
2019 Ranger XLT
Just filled up third time. First two 87, now did 91. Been getting 16.7 MPG with a relatively light foot, and 70/30 city/highway driving. I have the sub 2k RMP rumble, and sometimes it feels like it doesn't have ooomph on the freeway/not engaging turbo boost. My expectation for 91 is a 911 killer, 30mpg, smooth as silk ride. IT BETTER BE FOR ALMOST $5/GALLON!
Mobius97
Seattle
Ranger Lariat Fx4-Lotus Evora-Lotus Elise-BMW X7 M
Ouch $5 a gallon!!! I thought we were high. My area is is Reg $3.17 Mid $3.57 Prem $3.60.
Psykostevo
Queen Creek, AZ
I can tell you that the stock tune is programmed for much more power than the advertised output if you use high octane fuel and allow the ECU to adjust over some driving (or by pulling the battery, etc).
Hounddog409
Tod
Ohio
F150
All those silly saying don't mean much, HP is what ultimately makes a rig move and what creates work. 800 ft lbs and 200 hp vs 400 ft lbs and 400 hp, the latter is going to be able to do more work.
you are completely backwards. torque is that gets the job done. HP is simply torque ( the work) over time.
The formula for HP is TORQUE x RPM. with a constant thrown in. HP does not create the work. its the result of the work.
Torque is real. Torque can be measured.
HP is calculated.
See the difference?
ben8jam
Ben
Los Angeles
2019 Ranger XLT
Well I did not experience Ferrari like acceleration in the first 10 miles of driving on 91, BUT I'm willing to give it a few tanks to see ;)
Oregon Comrade
Portland, OR
2019 Ranger FX4
HP is calculated.
See the difference?
It's not intuitive, but torque doesn't do any "work" that's why HP is king. You can put a big breaker bar on a bolt, you can apply lots of torque to that bolt but if it doesn't move, no work is being done....aka you don't actually do anything.
Again, we can use a more extreme example....which one would you pick to power a large vehicle, lets go more extreme than even a F1 car engine?
Option A) 1500 HP @ 30,000 RPM; 400 FT/LB max
Option B) 600 HP @ 2,000 RPM; 1950 FT/LB max
Which would you pick and why?
@weasel1 @Psykostevo @P. A. Schilke feel free to jump in with your opinions....
Psykostevo
Queen Creek, AZ
From my experience 91 alone won’t hit the fully advanced Octane Adaptive Ratio, but it will give you a higher value than 87 would after it adapts. Be sure you floor it aggressively here and there to let it see that it can explore more range safely.
jeepwranger
pittsburgh
'16 wrangler
The formula 1 engine won't be able to move a semi trailer. Not with any kind of transmission that you could actually buy.
Oregon Comrade
Portland, OR
2019 Ranger FX4
Of course not with current transmission - it's conceptual, and we need to ignore durability, but a transmission could certainly be designed and the physics are still valid, it could easily power a semi.
Cape Cruiser
Bret
Southern Delaware
31 Ford-20 Ranger Lariat FX4- 19 Ranger Lariat 4x2
retired mechanic
Easy option B time to end this one. There are enough auto engineers to put this to rest!
Oregon Comrade
Portland, OR
2019 Ranger FX4
Not that easy.
I guess all the engineers that designed the Abrams tank and it's corresponding turbine engine could learn a thing or two:
https://en.wikipedia.org/wiki/Honeywell_AGT1500
It's important to note, the engine has a 10:1 reduction unit bolted to it, crankshaft spins at 20,000+ RPM, it is reduced down (through GEARING) and has 2x the torque as option B. That's exactly why HP matters and torque is largely meaningless....gearing.
