Faded Window Trim Restoration
Here
XLT
There's no need for this because the regular Graphene Nano coating does the same thing. They have several products like this (similar to others they have) and I think the only reason they do this is some people use others coatings like Mothers and then will use this for their trim. With the Graphene Nano coating you can use it on all everything.
The 303 Aerospace Protectant and the Marine Aerospace Protectant are the exact same product. I asked the chemist about this years ago and he said the just tailer different markets like this.
From their website
Gotcha, thanks.
So…
From their website
With the fading of the trim on my 5G, the first thing I did with the 6G was get some 303 and did all the trim. When I get the chance and it's not too hot out, I'll do the rest.
While the Aerospace protectant works great I like the Graphene better for the outside trim/rubber. It seems to last longer and protect it better with the added Graphene in it. I use the Aerospace protectant on all my interior and only do that 2-3 times a year.
I can't keep them straight, this is what a got:
https://www.amazon.com/dp/B08K3N5QP5
That's the one. You can use it on everything (glass, plastic, rubber and body panels) on the exterior but don't use it inside, use the Aerospace protectant inside.
I used it on my new tonneau cover as well. Right after install.
On my '19 Ranger I used the Aerospace Protectant on that since it was a soft tonneau cover. My Tremor is a hard shell so I just use the Graphene on it but either works great and it comes down to convenience and preference. The only thing you don't want to do is use Graphene inside because of the fumes. It'll work but you'll be flying. :crazy:
Duly noted!
quangdog
Kimball
Meridian, Idaho
www.youtube.com
2019 Ranger Lariat FX4
The black trim pieces that run along the top edge of the door right up against the glass have started to fade in the sun. They are relatively easy to remove: one single fastener on the inside of the door skin pops off one end and then the whole thing lifts up and off the door. I thought it would be easy to simply paint them, but I’m not sure what type of paint I should be using. The small rubber flap that is molded into them would be really difficult to mask off properly.
Has anyone already tried to address this? What process did you use? Is there a specific paint or product I should be considering?
Or, is it better to just simply replace them with new ones from Ford?
I’d be grateful for any advice anyone can offer.
Thanks!
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
