Racket
- First Name
- John
- Joined
- Jan 21, 2020
- Threads
- 22
- Messages
- 2,240
- Reaction score
- 3,515
- Location
- Here and There
- Vehicle(s)
- 2019 Lariat Supercrew 2WD
- Occupation
- Transient
- Thread starter
- #16
Hi John,
Thanks Phil. You've done a nice job of validating all if us in this thread I think (?).Hi John,
Al is correct that increasing roll stiffness at the front will promote more understeer. By design and tuning, the truck understeers as almost drivers are more comfortable with understeer and more unsettled with oversteer. Some folks use the term Push and Loose. (read NASCAR...). So making the front bar more effective due to the aftermarket bushings will change the roll stiffness balance and introduce more understeer. If this is your desire, then you are on the right track. If in fact you want to tighten up the car you might need to add a rear bar to keep the roll stiffness balance front to rear close to what you currently have.
Put another way, The tires have the greatest slip angle on the stiffest end of the truck, currently the front of the truck. That is why I question just installing a Helwig bar without an associated adjustment tweek at the front to maintain balance. I ask the question...do you expect to loosen up the truck? If so...add the Helwig bar.
Make sense?
best,
That's what I'd do, although do the task myself.With my handy dandy new electronical caliper I can confirm the front factory sway bar is indeed 27mm in diameter at the frame bushing and 100mm bolt to bolt for the bracket. As of yet I haven't found any quality replacements. An option I might pursue would be getting smaller diameter bushings and have a machine shop open them up?
