TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 45
- Messages
- 3,936
- Reaction score
- 9,880
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
- Thread starter
- #1
I've been holed up recovering from disc replacement surgery, and have had a lot of time on my hands. I've been thinking about how to cure the moisture contamination issue that is causing failures of the DPFE sensor
And I came up with an out of the box crazy possible solution that I am going to run across this group. But first a question for those in the know.
How hot does the hoses and sensor become from the exhaust gases? I figure temps can't be too extreme as the hoses wouldn't stand up to the temps.
Anyway here's my crazy idea. Why not insert an old time fuel sediment bowl filled with desiccant balls in the inlet hose before the DPFE sensor. The ones that change from blue to pink when saturated with water. Heat them up to release the moisture, they turn blue, then reinstall them in the bowl. If the inlet temps are not too high the desiccants will capture the moisture.
I can run the truck and measure the hose temps which should be enough to know if the desiccants idea will work and if I need a glass or polycarbonate bowl.
I would need to modify to remove the shutoff valve and add brass hose fittings, but easy enough to do.
Or use something like this pneumatic water filter ?
Any downside to trying this crazy idea?
I'm only out $15 for the glass bowl to to try it, and if fails I simply splice the hose back together.
Thoughts ?
BTW, the neck collar and bandages came off today, and I'm free to start to increase activities "within reasonable moderation", whatever that means. I could not get a definitive answer no matter how I rephrased the question! Anyway I got me a new improved BIONIC neck. I gave the doctor an 8 on the scale of 1-10. I told hom it would have been a 10 if he had given me a set of Frankenstein Battery Posts on my neck.
He laughed at that one!
Thoughts ?
