DPFE - to replace now or wait?
derekw24
Derek
NC
2020 Ford Ranger XLT Sport 4x4
Accounting
Hi all,
Just received the DPFE sensor assembly, in the process of doing some preventative maintenance on the truck.
Had my transmission rebuilt/overhauled In Jan so that helped with shifting a lot but still noticing some weird lurches in low speeds which i suspect could be related to DPFE.
I have no clue if this would matter either way but I will be doing an oil change (going to do it my 1st time using Valvoline Restore and Protect since I bought it at 91k miles) and running some redline s1 fuel system treatment. Should I do those things first and then change out the DPFE sensor or would there be no difference in the order?
Probably a dumb question but figured i would ask and see. TIA!
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Check to see of the egr tube on the back of the engine is hot. It should be pretty warm after a drive. Mine was borderline cold. I threw a light but there was a lot of crud built up on my tube. Maybe I had a messy oil change 2 changes ago. But that means for thousands of miles it didn’t get hot enough to burn it off.
Now with a new sensor it burned it all off. Tells me my egr wasn’t working efficiently. Additionally it idles smoother and my mpgs seems to have increased to what they were before. I blamed it on winter fuel, i was wrong.
derekw24
derekw24
Derek
NC
Accounting
Interesting! That is good to know. Which tube should I be looking for exactly? I know the dpfe sensor is on the drivers side and then the egr is kind of on the passenger side if i’m not mistaken?
