Electronic Locking Differential Turns off on corners
humanprimate
Ian
Madras, OR
2019 Ford Ranger Lariat
Science teacher
A couple times (totally randomly) the electronic locking differential turns off on when taking a corners and the truck jolts through the turn. I haven't deactivated the system at the switch and I have to pull over, turn the truck off and wait a bit for it to stop happening. What am I doing wrong?
Aonarch
Alec
North GA/ Montana
How fast are you going? Doesn't it unlock at a certain speed?
25 mph? It probably is in the owners manual.
You shouldn't have the locker on while taking turns anyways.
humanprimate
humanprimate
Ian
Madras, OR
Science teacher
This icon comes on during corners. Normally the icon is off. It happen at stop signs and when I turned into the driveway.
humanprimate
humanprimate
Ian
Madras, OR
Science teacher
I'm an idiot, I figured it out. Thanks for the replies. I accidently hit the button on the console which locked differential but it only activates when I slow down for the corners.
BiilyJones
2021 Ranger
Heavy equipment operator
If you are using the locker on conering, you should turn off the traction control and mash the accelerator. ?
Only if you want to grenade the rear axle, this is a know fact with the F series trucks with factory Elockers.
Langwilliams
Langley
Lorain, Ohio
My understanding is you have to be going under 25 for it to lock but once locked it won't/can't unlock until you let off the gas. I have accidently turned it on once or twice reaching for something in that tray ahead of the shifter.
I must have been real lucky, several times. Or maybe you are just spouting opinions as fact again.
Certainly not a Opinion and certainly a fact. Common sense should already tell you to not do that with a locker anyway
