Drive shaft center bearing
Todd
Todd
New Jersey
2020 Ford Ranger
LE
Recently had to replace drive shaft center bearing on my 2020 ranger, started with a vibration and thought it was my tires - had them rebalance and mechanic felt the vibration I felt.
Well, we put it on the lift in the air and ran it slowly and center driveshaft bearing was bad. Had ford replace the entire driveshaft with new bearing and fixed the problem (cheaper to replace all of it then to fix bearing). Well, this past week because of that issue and cheap steel rear differential seal started throwing bearing oil ! Changed the seal and 4 days later leak again - well the flange is a cheap steel and just from the seal wearing it caused a groove that let oil out.
So, if you replace the seal also do the flange, so far so good for the end of the year..
woodworker
Joel
virginia
2021 Ranger Sport
Got a new drive shaft coming in to Ford now.
06Warrior
SW Florida
2020 Ford Ranger XLT
Staying busy
I went thru the same thing.
My center support bearing was squealing. Ford replaced the center support bearing with a new one.
A year later it started squealing again but intermittently. Brought it back to the dealer but since it was squealing intermittently if they couldn’t replicate the squealing noise I would have to pay for the diagnostic fee.
We were leaving for a trip with our camper and I ended up buying a complete driveshaft and replaced it my self.
woodworker
Joel
virginia
2021 Ranger Sport
Ford wanted $1500.00 just to replace the bearing. NOT..!!!!!
ScarzRanger21(2.0)
Eric
Auberry, CA
2021 Ranger 4x4, 2019 Ranger Fx4
Electrician
The bearing on my wife’s ranger squeaks intermittently. We took it to the dealership once to have them look at it but they said they couldn’t replicate the issue and couldn’t do anything. I guess until it starts happening all the time, I’ll just wait. Her truck is still under warranty so I’m not going to foot the bill to replace it. If it fails, Ford can eat that cost.
Todd
Todd
Todd
New Jersey
2020 Ford Ranger
LE
Attached photo of bad flange- arrow showing wear groove enough to catch your fingernail in - caused from seal 68,500 or so miles, and what new looks like. My brother-in-law (mechanic - said there is a company that can sleave the old one? so kept it and will see what the cost is? New flange $200.00 and change from ford and don't forget new seal
Todd
Todd
Todd
New Jersey
2020 Ford Ranger
LE
The way I confirmed the center bearing was bad, my Brother-in-law put the truck up on the lift and idled up and watched the vibration and severe shake.
woodworker
Joel
virginia
2021 Ranger Sport
I kept the old drive shaft too.
Stevedbvik1
2022 Ranger Tremor XLT
When did Ford do the driveshaft swap? Did they update it to the Tremor style ( 8 bolts at the rear diff) ?
woodworker
Joel
virginia
2021 Ranger Sport
New driveshaft is installed and the noise went away and no vibration at all.
Brought the old driveshaft shaft home for justin. You know, Justin Case…..
The first one went just over 148,000 miles so we’ll see how this one does.
06Warrior
SW Florida
Staying busy
Yep I still have the old complete driveshaft for just in case.
Todd
Todd
Todd
New Jersey
2020 Ford Ranger
LE
Just had it done in December did seem any different as far as upgrade to Tremor shaft
