Maybe but I don't have a need to. Also going down further it would be best if I had bead lockers.... And I do not have suchThe XTs are 10 ply though, no? Doesn't that mean you can air down further than AT2 (4 ply) without the bead seal breaking?
I run mine at 32 cold and rotate them every 5,000 miles. So far they've been wearing great.Thank you both
As a sanity check, what pressure do you run on the highway?
I did the chalk test, and came up with about 33-34 psi -- although I think the 34 would be optimal with cold tires, not yet running hot. So perhaps 33 psi, so that when hot it's more even wear.
