Data Collection for Ranger Rear End
psweeney
Patrick
LA
2019 Lariat FX4 (well, it started that way)
Hi Everyone! I'm looking to get some numbers from everybody on their trucks so I have some more information on variances, etc. Anyone who has a minute (stock or not/list what work done to the rear if any), I would really appreciate it!
Just looking for 1 measurement from each side while the truck is on FLAT GROUND (or all 3 if you have time, and all on the REAR END of the truck ONLY):
1. From ground to wheel arch/fender on each side
2. From center of wheel hub to wheel arch/fender on each side
3. From top of tire to wheel arch/fender on each side
Please measure both sides (part of this experiment is because I'm finding some fairly interesting and non-insignificant variances in these numbers side to side and truck to truck).
And if you can note any differences side to side in the actual equipment, that would be great as well (for instance, mine had an extra 3/4 inch shim under the left side U-Bolt/Leaf Spring from the factory that wasn't matched on the right so you may have some interesting one sided equipment too).
Also, note if you could 2wd or 4wd, tire pressures, and gas tank fill level as those can all affect the numbers.
Thank you all so much!
